New receiver
Username: Sluggp
Post Number: 38
i know this probably gets asked here alot but i looked for some answers first and havent found any good advice yet...I currently have a viewsat extreme and am looking to buy a new reciever. Anyone have any advice on which box to get. The extreme is the only one that ive used so im very unfamiliar with any others. I dont think you can find extreme anymore....what about sonicview..they seem to come out with a fix pretty quick..
Username: Saqeeb9000
Post Number: 4366
john due if u are looking for some thing that stays up longer (lol bad wording)..
i would recommend nfusion,
its best for "more up" time,
and now its on sale,
so buy navineo or hd model
nova has less memory/lack of pvr/usb/slow channel change
navenio has more memory/ lack of pvr/usb
little faster channel change
nf hd has above things that are missing
cost wise nova around $ 160-navenio around $ 200 and hd is around $ 450,
so depends how much u wanna spend
support website
[link removed]
Post Number: 4367
and yep nfusion rec needs constant internet connection,,via ur router/
if u don't know about it,
Username: Sluggp
Post Number: 39
is there a risk of your ip address being tracked?
Username: Lomna
Post Number: 420
John doe..Answer to this really depends on, to whom you are asking about it (IP adr) If you ask me I won't take chance.
Username: Yuvrajs
wait nfusion is coming with new solaris box.
