I have a 86 GMC Jimmy SUV. I would like to know which subs would do best in a suv.Im thinking either Kicker Solo X 18, RE Audio XXX 18, DD Audio. What would do best in a SUV. Im lookin for loud DEEP hard hitting bass that'll shake the whole block. Im lookin to spend about 1500 dollars on the subs.Also need help with a amp.What would be a cheap yet good amp.10000 watts minimum. Or what would be some good amps to hook up to a maxx-link.
Yes, I want to run 10k daily. Matter of fact, I might run 20k daily.I just got off the phone with a friend who distributes Powerbass where im from.They just came out with the new 4XL 12's. They also just came out with a 12,000 watt amp.So im thinking 4 12's and 2 12,000 watt amps.Ill also be able to get them WAY WAY below msrp.
you are gonna tear your cars electrical apart runing that daily y not get one or 2 good subs running 3k rms its all about the install i promise you you can build a system that your wont be able to sit in the car its so loud with a lot less than 24k rms
thats really what im looking for, I want a system where I cant even sit in the car with it half way up, then I feel that it'll be enough.I just dont want to upgrade and still not be satisfied. About 5 months ago I bought 3 Nitro 12's and a Crunch 1500 watt amp.Its loud, loudest in my circle, but still not enough. It also doesnt hit the lows like I want it. Has anyone ever used Powerbass. My friend been distrubiting powerbass for about 6 years now, and I have to say that its the best bang for your buck.
