Silver Member Username: Bernardmi
Post Number: 200 Registered: Dec-07
Posted on I re-oriented one of my antenna a few days ago to Galaxy 25. Great foreign FTA there ! Lots of encrypted channels however ! Are these Globecast channels ? I have tried to enter GC key into the Viewsat code pages but cannot succeed. Can these channels be viewed or are they special encryption ? |
Post Number: 201 Registered: Dec-07
Posted on Bump !!! |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 3471 Registered: Oct-06
Posted on Basic bin should work on GC What is yor receiver? Which specific channel are yo refering to? |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 3968 Registered: Jan-08
Posted on The Outer Limits Try it Delete all keys for Gc reload bin file and enter this keys C1 01 00 00: 55 04 d5 a8 c9 31 3e a9 01: e1 f3 89 9c da 61 8d d7 08: 49 D4 CC 8A 3C D5 68 1E 09: EE E6 3A 17 8E D4 DC 62 88: 88 57 C2 D7 ED 0C 62 6E 89: AD 44 41 77 2C 86 6A 4F |
Post Number: 202 Registered: Dec-07
Posted on King I have a VS Plat 2000. Let's say I want to get TVP Polonia USA on 12084 V. Or TVP Info or Tele 5. Solid signal and quality but no video. OK just tried Plymouth keys and it now works. Thanks all
Post Number: 203 Registered: Dec-07
Posted on OK now if you go to dss keys dot com and scroll down you get GC keys in 16 bytes lines. Listed as line 00 and line 01 Plymouth you split them to lines 08/09 and lines 88/89. Do you always put the GC keys in 08/09 and 88/89 ? What are lines 00/01 any good for ? |
Quebec city,
Quebec
Post Number: 3969 Registered: Jan-08
Posted on The Outer Limits All sites give keys as dsskey This is complete lines for Viewsat receivers Yes you must split them to lines 08/09 and 88/89 You do same thing in each provider(0nly 00/01 i dont know
Quebec city,
Quebec
Post Number: 3970 Registered: Jan-08
Posted on Gc does not have autoroll, you must always enter keys |
Post Number: 204 Registered: Dec-07
Posted on Thanks/Merci Plymouth |
Silver Member Username: Elmoxp
Ottawa,
Ontario
Post Number: 208 Registered: Jun-06
Posted on I want to get Galaxy 10R from Canada, what Dish size do i need? |
Quebec city,
Quebec
Post Number: 3972 Registered: Jan-08
Posted on The Outer Limits You are Welcome |
Quebec city,
Quebec
Post Number: 3973 Registered: Jan-08
Posted on Emilio Galaxy 10 Ku-band (123w) Dish: 30" (1.2m Hawaii/Canada/Carribbean) LNB: Linear Galaxy 10 C-band (123w) Dish: 6' Which channels you want get? |
Ottawa,
Ontario
Post Number: 209 Registered: Jun-06
Posted on Thanks plymouth, i want to get Spanish channels, Univision and Telefutura there |
