My GC went dead
Username: Machedonul
Post Number: 366
did the codes chnage? GC stopped working for me 5 min ago on a pansat 2500
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3825
All up
Username: Sam5002
Ny, Ny Usa
Post Number: 91
GC is down on my VS Ultra..even I did factory default, changed the code but no luck :-(
Username: Plymouth
Post Number: 3833
Go in key menu and nagra and delete 2 provider C0 01 00 and C1 01 00 with F3 on remote, and reload last bin from ftahq.com
Note all your satellite settings before, because that can delete all the setting inside the Box.
Check if you have good key, if no enter new keys in good lines.
Username: Lavaboy
Post Number: 28
Hey Plymouth, what size dish and lnb type are you using to get GC in Quebec?
Thanks
Username: Plymouth
Post Number: 3841
Lavaboy
I use a 33" and a Invacom QPH-031 LNB and a HH-90 motor.
Username: Lavaboy
Post Number: 29
I guess that means I am out of luck with my old dual standard lnb dish 500 set up. thanks
Username: Plymouth
Post Number: 3944
Lava boy
This is not the best for get Gc
You need a 30" and higher and a universal Linear LNB for get it, depend your location.
I recommand to buy a 36" and HH120 motor and a QPH-031 LNB.
I have 2 dish with motor a small 18" and a 33", i use two receivers, Viewsat Ultra and Captiveworks 600S Premium, Ultra is the best to use with motor and for use on true FTA, the CW have some bog with motor, Exemple if i do a channel recall between 2 sats, the motor lost the position and i need to go in satellite menu, cw is slower for track a new satellite.
Username: Sam5002
Ny, Ny Usa
Post Number: 93
Thank you very much Plymouth
I could fix my GC as per your instructions. Thanks a lot.
Username: Plymouth
Post Number: 3952
Sam
You are Welcome
