2 amps , 1 sub?
Username: Godemiche
Quick Q, Can you hook 2 amps up to 1 sub?
I got 2 amps, each 100x1, can I hook both of these up to 1 sub.?
like the positive from one, negative from the other?
just wondering....
Username: Jamtochristian
Penn State , Pennsylvania USA of course!
Post Number: 46
If it has Dual Voice coils than you can hook each amp up to a voice coil, and that'll work fine for you. If its only SVC, I wouldn't recommend it.
Username: Kragan
Post Number: 26
If it is a SVC they do make certain amps that can do that ... but I have only seen FEW models that can and they are normally huge amps and only used moderatley for dB competitons and the like
