Connect 2 amps to one set of speakers.
Username: Mpioman9
Georgia United States
I'm buying a box with 2 12" subs in it, but there is only one power connector on the box for both of them. I have two amps that have enough power for one sub each. Can I safely connect both amps to the one power connector for both subs?
Username: Th3pwn3r
I compensate...
Post Number: 8686
Just pop the subs out and run wires through the box by drilling a hole large enough to get the wires through, make sure to tie a knot in the wire on the inside of the box so it can't pull through and then seal up the holes with some silicone.
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 363
id do one amp per sub. if u dont know the amos soecs and the sub specs u could easly burn the voice coils or the amps.
Username: Mpioman9
Awesome. Thanks for the advice. I had no idea what to do, because this is my first stereo system. I was scared of blowing the pair of subs that I spent almost all of my money on (I'm in high school with no job). Thanks again.
Username: Ducka
Shelby Township, MI United States
Post Number: 408
