Comcast DVI to HDMI Connection on LCDTV
Username: Turkeyridge
When using a Comcast HD Box with DVI output connected to HDMI port on VIZIO TV, every time you cut the TV off the Comcast box resets itself to 480SD and thus the HD TV does not recognize the signal. Help? Its not the TV or cable, been replaced and comcast box exchanged.
Username: Levelzero
Post Number: 62
Does your Comcast box have a HDMI port also?
Username: Chitown
Post Number: 1374
Take your cable box back to comcast. They can give you another with an HDMI input now.
