Help on my panasonic dvd
Username: Lambytd
Hi there i have a panasonic dvd and t.v my dvd player is sa-pt450 and i would like to put camcorder video's on to a disc and play them on my t.v i have tried this dvd+r and dvd-r but it won't play them could you tell me if there is any reason for this thanks mark.
Username: Samijubal
Post Number: 3929
What are you using to record to DVD-R?
Username: Tapeman
New York City in-HD, NY
Post Number: 3480
When yo record on DVD-r yo must finalize disc to become a playable DVD disc
Username: Lambytd
What i have done is i have downloaded a video from my camcorder to my p.c and then i have put it on to a disc pretty sure it's gone on to the disc but it won't play on my cd player it just say's on my t.v that it is not compatable.
Username: Levelzero
Post Number: 66
Is your dvd burning software set to be compatible with your DVD player? Be sure the region code from the software is compatible with the dvd player you have.
For instance, if your burning software is set to NTSC (Region 1 - US), but your dvd player will only play PAL then you will continue having problems.
See if you can set your burning software to be region free.
Username: Samijubal
Post Number: 3930
All burn software is region free. I'd guess the burn format isn't compatible with the player. The DVD standard is MPEG 2. I don't deal with camcorders and can't really give any more help.
Username: Lambytd
NottinghamEngland
I'll give it a try thanks for your help Mark.
