New member Username: DenonPost Number: 4 Registered: Nov-07 | i just bought a new sound system for my car and i took it to my local audio installer and he said that my car would just struggle to power it so i asked if i bought a bigger battery and alternater would that work he said it would but i would also need a power cap when i asked what size battery and alternater i would need he said said he didnt know which has left me in a pickle because i dont know who else to ask so ive tried here to see if anyone can help my car is a suzuki vitara jlx 2door soft top 1992 model and the battery is only small so im assuming that the alternater is only small to ill list the amps below that i bought HIFONICS GENERATION XX SERIES XX COLOSSUS II 3,200 WATT RMS DUAL MONO-BLOCK CAR AMPLIFIER this will be powering 2x 4000watt subwoofers and i bought a 4 channel amp to give the 4 car door speakers better sound thats a JENSEN JPA-460 600w 4/3/2 CHANNEL CAR AMPLIFIER AMP please if someone knows could they tell me or point me in a direction on what size battery and alternater i would need and where id be best buying one from also would i need a certain type to fit my car or do most alts fit most cars. also if possible if i list the items i bought would someone be able to have a look and send me a wiring diagram or a step by step guide to explain/show how i would wire it up as it would save me alot of money the items i bought ill list below http://audiosavings.com/product_details.aspx?item_guid=512bfe43-922c-4258-ba76-6 fc915c5de3e&category_guid=ae183c37-906d-46ae-836c-f5b5c6d4305f this next amp is to power the 4 car door speakers http://cgi.ebay.com/NEW-JENSEN-JPA-460-600w-4-3-2-CHANNEL-CAR-AMPLIFIER-AMP_W0QQ itemZ270180026585QQihZ017QQcategoryZ39739QQcmdZViewItem and these are the 4 speakers i got for the amp for the doors http://audiosavings.com/product_details.aspx?item_guid=73cdd973-abf9-4652-8c25-d 9db1902fe0d&category_guid=219420be-b87b-4170-b250-5d61698437a9 and i bought this wiring kit for the jensen amp above http://audiosavings.com/product_details.aspx?item_guid=10a371ff-59ec-46ad-ab67-1 11861eaa058&category_guid=b4b9f579-9efa-4066-96b4-4cd6d0709731 hope this makes sense and hope someone can help thanks |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 12102 Registered: Dec-03 | WTF does this have to do with EQs and Crossovers? stop cross-posting, for Christ's sake. |
Bronze Member Username: DenonPost Number: 16 Registered: Nov-07 | hi wolf sorry for cross posting im just an impatient git and thought if i posted on more threads id of got more answers i looked to see how i take my thread off but i cant find how to do it so if anyone knows how to take threads off please could they let me know and ill remove it |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 12107 Registered: Dec-03 | this was already answered (by me even) in accessories. we all ready the same forums, so we all see the multiple postings. |
New member Username: MrsquaLong beach, California Post Number: 3 Registered: Jan-08 | man that was anoying jordan. please dont do that multiple posting again |
New member Username: IndicaproNunya buzz, Cali USA Post Number: 1 Registered: Aug-08 | id takeyour alt. and have it re-wound by a local alternator specialist itshouldnt costyou over 250 bucks. as a stinger alt. built for systems are really expensive like in the 700-100 dollar range. you dont need a capacitor, they are even harder on the charging system, instead get an additional battey for the trunk and also replace the underhood one with the same type that you are using in the trunk. id say you want at least a 150 amp alternator. so if you have itre-wound tell the man what amperage you want from it. yes that is a hell of an amp look for batteries with at least 140 researve capacity and 1000 cca. really and trully, stiffening capacitor's are murder on a charging system thatis already having trouble keeping the voltage up to par, and an extra battery in the trunk (or 2.lol) acts like a stiffening cap. whereas it has juice ready at hand to send tothat amp on demand. |
