New member Username: Flamingo114Post Number: 8 Registered: Oct-07 | I am about to order the Superpower 33" elliptical dish with 5 LNBs to receive Dish 110 118.7, 119 and Bev 82 and 91 and I would like to know what switches and how many would I need in order to set this up with an existing Dish 300 that I have for Dish 61.5. I am using 2 pansat hd receivers. Thank you. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3407 Registered: Oct-06 | Don't waste yor money Won't work Get 2 dishes instead |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3408 Registered: Oct-06 | This question keeps coming However I don't recommend it unless yo know what yor doing This is what they claim: But good luck try to get right angle and signal 33" SUPER ELLIPTICAL DISH 1000+ 500 SATELLITE 118.7 LNB Piece-a-cake with 2 dishes instead Here is yor switches: 5 Sats 8 Sats |
Platinum Member Username: NydasPost Number: 11587 Registered: Jun-06 | Digiwave makes a 8 to 1 switch. I have seen it in Toronto market for about $35 |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3412 Registered: Oct-06 | DGS-SW8x1 From e-bay About $20 Or yo can make yor own 8x1 SW using RG-6 cables 2 DISEqC and 1-22K switch |
New member Username: Flamingo114Post Number: 9 Registered: Oct-07 | But how do I set this up going to two seperate receivers? |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3414 Registered: Oct-06 | 4 Satellites to 4 Receivers |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3415 Registered: Oct-06 | 4 Satellites to 2 receivers - Yo have to have each Sat on a separate LNB - Each LNB must be dual input - Yo may place 118/119 on one-LNB One-input - Third Sat to input-3 - Forth Sat to input-4 etc. - Max 4 inputs to 2 receivers |
Silver Member Username: LuserPost Number: 325 Registered: Nov-07 | 2 sw21's in front of 2 dp34's is the ticket. Besides wouldnt your reciever need to know what a 8x1 is first? I mean its not in my veiwsat setup menu. |
Platinum Member Username: NydasPost Number: 11594 Registered: Jun-06 | A number of variations of DiSEqC exist: * DiSEqC 1.0, which allows switching between up to 4 satellite sources * DiSEqC 1.1, which allows switching between up to 16 sources * DiSEqC 1.2, which allows switching between up to 16 sources * DiSEqC 2.0, which adds bi-directional communications to DiSEqC 1.0 * DiSEqC 2.1, which adds bi-directional communications to DiSEqC 1.1 * DiSEqC 2.2, which adds bi-directional communications to DiSEqC 1.2 Even the lowly Pansat 2500 and FLU using the conversion BIN PUFF_288 has a DisEqC 1.1 setting, which is what is needed for the Digiwave 8 to 1 switch. The latest BINs on viewsats should/would have 1.1 and 1.2 DiseqC settings |
Silver Member Username: LuserPost Number: 329 Registered: Nov-07 | I do remember seeing diseq sw1 and sw2 for a total of 16 on a 2500. I guess VS is a little behind in the diseq department. I was pretty impressed with that little 2500a after getting through all the do's and dont's and do's it took to load the file. |
Platinum Member Username: NydasPost Number: 11599 Registered: Jun-06 | The DisEqC 1.0 and 1.1 alternatives came about on Pansat 2700 (and therefore on converted BINs) about 2 months ago. I am pretty certain that that kind of facility is becoming universal amongst the better FTA names |
Platinum Member Username: NydasPost Number: 11601 Registered: Jun-06 | https://www.ecoustics.com/electronics/forum/home-video/513887.html |
