Help Viewsat Platium
Username: Sunshine123
Post Number: 48
Please Help anyone.
Can someone help me with my antenna setup
Put wrong bin into box and I think my Main Menu Antenna Setup is wrong.
All I get is searching for signal
The S reads 62
The Q reads 00
Post Number: 49
Plymouth can you help me ?
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3766
Leaf
Which satellites?
How many satellites?
Do you have switch?
Post Number: 51
Plymouth not sure by what you mean
I think my problem is in my Viewsat Platium box
Not sure by what you mean by satellities?
Please explain still a newbie at this
Post Number: 52
I believe I was At EchoStar 10.11 110.0W
Post Number: 53
Antenna Setup EchoStar 10.11 110.0W
Satellite reads Echostar 7 119.OW
LNB Power On
LNB Type OCS-DP
LNB FREQ 11250
22KHz OFF
TP FREQ 12224
DISEqC 1.0 PORT 2
MOTOR OFF
LEGACY SW NONE
Maybe this wrong Setup for Viewsat Platium ??
Username: Plymouth
Post Number: 3767
Leaf
If you see Echostar 119.0W and you want get 110W, turn to left a little and go up a little( when you are in back of dish)
LNB Power On- Ok
LNB Type OCS-DP -Try standard
LNB FREQ 11250 -Ok
22KHz OFF
TP FREQ 12224-Try 12486 for 119W, 12239 for 110W
DISEqC 1.0 PORT 2 -If you have only one satellite, choose none
MOTOR OFF
LEGACY SW NONE
Post Number: 54
Plymouth not sure what i am doing wrong but still no luck will try again
Keep geting Searching Signal message
Weird got one or two channels but thats it?
Maybe Hurricane IKE is messing up things as well
Thank you my friend
