Wire question
Buster
would it be better having 2 or 0 gauge power wire running from the battery, to a distribution block, and split into double 4 gauge for two amps? Or could it be 4 gauge all the way?
Username: Demigod33
Post Number: 13
what type of system r you powering
Username: Kragan
Post Number: 18
Need to know the wattage of the amps you are powering.
Buster
They are 2 JBL 1200.1 amps. I already have a 225 amp alt if that helps.
Username: Davids2004
Houston, TX USA
Post Number: 35
Always the bigger the better. The bigger the wire the more current that can flow and allows your amps to run easier because its getting the current it needs. So go with 0 gauge to the block then 4 gauge out.
