davidsmith Unregistered guest | I just bought a new Jl audio W7. I was gonna get a jl audio 500/1 amp for it but due to enexpected expenses I don't have enough money for that. I was wonderin if anyone had any ideas for a cheaper amp that would do a good job of pushin it. |
Silver Member Username: Sploosh56Post Number: 108 Registered: May-04 | What size di you get? |
Anonymous | Get a JBL 600.1 $220.00 at www.sounddomain.com |
davidsmith Unregistered guest | its a 12inch |
Anonymous | yeah get the JBL it will push it hard. |
davidsmith Unregistered guest | r you sure the jbl supports the 3 ohm load? |
davidsmith Unregistered guest | and it says its 600rms @ 2 ohms so wouldn't that make it 450rms @ 3 ohms.. would that be enough since it can hold 750rms? |
Anonymous | it support all the way to 1ohm it will push it but you really should go to Ebay and find a JL500/1 on there I just saw one a second ago for $213.00. JL subs really need JL amps to run them good though so try ebay. |
Anonymous | that would be ok it wouldn't hit as hard as a JL 500/1 thats why I said try ebay. |
Silver Member Username: Sploosh56Post Number: 109 Registered: May-04 | Yea get a JL 500/1 |
