If you have "Lost Channel Edit and Parental Control" it is usually because there is no sat scanned. The thinking as per Pansat programmers goes like this: "If you do not have any channels scanned you do not need to edit them and you do not need parental control" - a very reasonable attitude.
Again newby. Menu/Antenna Set-up/Satellite Indeed, no selected satellites. EchoStar 110 or 119 not found within list (Begins G-25Ku). Right place to start? Suggestion/s?
Why problem? F----- self by following "Arkansas trying to get Tennessee channels." Unclear. Pressed delete factory settings
select echo 7 for 119 and echo 8.10 for 110 , assign proper diseqc port usually port 1 for echo7 and port 2 for echo 8.10 , also select lnb type for each - usually standard or dish pro.
What is your Dish pointing to? What sats were you getting before? How many dishes? Look at menu/Instalation/ Antenna setup - what appears on the right? What does each connected antenna show up in terms of DisEqC settings?
Factory settings is what he is looking for not factory dwonloads. They are usually incorporated into the BIN. He has already said that he has no channels scanned and THAT'S WHY he cannot do a channel edit or parental setup. Black hawk, the child. GO TO SCHOOL
Tooter/Nalin Q 1: TY. TY. TY. TV working fine. TY. TY. TY. Q 2 Can I add Orlando FL channels (Echo 10 @110) in addition to Atlanta channels (Echo 7 @119)?
