Good Combination?
Username: Comerz
Post Number: 130
I am a day away from ordering my component speakers and amp. I was just wondering from a person who knows there stuff, is this a good combo or should i go with a diff amp, say a 4 channel or sumtin.
Comp Speakers:
-Diamond Audio S600's
Sensitivity: 91 dB
RMS Power Range : 20-170 Watts
Frequency response: 42-22000 Hz
Diameter: 6 Inch
And for the amplifier:
-Diamond Audio D3 400.2
2 channel
RMS Power @ 4 Ohm: 400 Watts x 1
RMS Power @ 2 Ohm: 200 Watts x 2
RMS Power @ 4 Ohm: 100 Watts x 2
Thx for the help guys.
Username: Drant19
DUB-C, TX
Post Number: 1171
those speakers r gonna need more power than that amp can put out at 4ohms. i would suggest getting a 4channel amp and bridging it to 2 channels.
Username: Comerz
Post Number: 131
are you serious? i guess i dont get how it works.
I thought because the component speakers are rated for 170 RMS and the amp was rated for 400 RMS at 4 ohms that the amp would actually be too powerfull for them, but this isnt the case?
Username: Snowball123
West Allis, WI United States
Post Number: 1035
noooo you look at what it puts out at 4 ohms times 2. Hince powering 2 speakers. The 100X2 @ 4ohms is the one you look at. Here i suggest this amp, the one i want to get. Very underrated, said to put out 200ish X2 @ 4 ohms.
http://www.cartronixplus.com/templates/detailnf_price.cfm?zq=51719397&uas=N&glob aldesc=na&rnumb=394&wherefrom=SEARCH&whichord=856238&department=ALL&class=N&spec ial=R&sold=Y&nextrow=New%20Rockford%20Fosgate%20T3002%20Amplifier%20AMPt3002&pre vrow=New%20Rockford%20Fosgate%20T3002%20Amplifier%20AMPt3002&nextprev=0&subclass =ALL&subname=na&pagename=Online%20Store%20%3E%20%20ALL%20%3E
Username: Comerz
Post Number: 132
pic didnt show up, it jus brought me to page to look at all amps, but yea that clarifies stuff up a whole lot better, thx snow
Post Number: 1036
no problem. The amp i posted up to is Rockford Fosgate T3002. Just google it, it'll pop up. That amp is rated at 50 X 2 @ 4 ohms, but will actually put out 200 X 2 @ 4 ohms from what I've seen.
Username: Comerz
Post Number: 133
I think i found the perfect match for them Diamond Audio 5600's, would this one be good for it?
Kicker 08ZX350.4
4 Channel
RMS Power @ 2 Ohm: 90W x 4
RMS Power @ 4 Ohm bridged: 175W x 2
Signal-to-Noise Ratio: >95db
Post Number: 1037
yes that would be good. But you didn't look at my amp? :-(
Username: Comerz
Post Number: 134
lol sorry man i posted that probably right when u posted yours, ill have a look. I still never decided what one i want forsure.
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2440
Chad you could also get a used JL 300/2.
Username: Drant19
DUB-C, TX
Post Number: 1175
that kicker will do just fine for those speakers. and FYI those speakers really need about 200rms to get that midbass to come alive. and make sure you sound deaden your doors to get as much bass as possible out of those speakers!
