Hi Need helpplz !!!!!!!!!!!! I an getting signal on some channels on 119 and 118 with special LNB but it says scrambeld or bad channel using diseq switch with 2nd dish facing 148 and latest bin 287 on puff receiver. anybody help plz will appreciate it thanks
The last 3-4 Pansat 2700 and conversions BINs have two tyes of DiseqC settings. 1.0 - 1,2,3,4, none 1.1 - 1,2,....15, none
You may have to change these settings. 148 is usually on port 3 or 4. Check your antenna set up with the above in mind. If not successful, post full details of Antenna set up of each LNB.
