Subs still wired backwards?!?!? help!
Username: Leapoldstotch
Post Number: 105
Again... ive got 2 12" cvrs. One of them is hitting the wrong way... ive got both of them wired the EXACT same..
I have all of the positives wired together and all of the negatives wired together. Then i put both pos. into the pos. part of the amp. Then i put both neg. into the neg part of the amp. Wtf is wrong? If one is hitting the opposite way, in a sealed box, is it taking away some bass?
Username: Brewsky
Prince george, British colu... Canada
Post Number: 67
is one of them blown?
Username: Turnmat
Racine, Wi
Post Number: 770
Depending on what ohm subs you have these are some of the wiring options you have. These first ones are for 2 dual 2 ohm subs
Wiring Option #1
Wiring Option #2
Wiring Option #3
The second option you have is for 2 dual 4 ohm subs
Wiring Option #1
Wiring Option #2
Username: Hittin1
Lake Charles, La. United States
Post Number: 1192
you sure both subs are the same Voice coil configuration?
Username: Turnmat
Racine, Wi
Post Number: 771
Depending on the ohm your subs are and the lowest impeadence your amp can go wire your subs according to the diagram that best suits your setup.
Username: Van_man
Boston South, MA
Post Number: 4255
wire each one separately and see if they work. if so, wire them up like the pics above to the right load.
Also a dmm would be able to tell you if the coils are bad. if they are dvc, maybe one of the coils is bad.
Username: Hittin1
Post Number: 1193
Check each voice coil with a DMM and post results....
Username: Hittin1
Post Number: 1194
sorry marc.. didn't see your post.
Username: Van_man
Boston South, MA
Post Number: 4256
np. good looking out.
Username: Mofogger
Post Number: 13
take the sub out and get yourself a battery and test it.
Post Number: 114
one of them isnt working. so now im just gonna have to sell em and get new ones ha.
Username: Hittin1
Post Number: 1204
next step is to figure out y it is not working.... not get new ones..... Might not be the sub...
Post Number: 115
i put a meter into the back of the box, on the pos and neg. it didnt beep. on the other one i did. What could be wrong?
Username: Hittin1
Post Number: 1206
check wire connections in sub box.(terminals) at subs and at termnal cup on inside if box
or
move working sub to non working side(or vice-versa) and see if it works.... if so the other sub is likey fu(ked up. If it doesn't work the wiring/connections are likely the problem
(if done vice-versa the opposite will apply)
or
pull subs out
check each voice coil with DMM. post results.
check tinsel leads
check voice coil jumper wires
just some suggestions
Post Number: 116
Well what i found out was, the wires that attached to the box were holding on by a tiny thread and a current wasnt getting through it.
Omg i thought it was loud before holy hell... its literally twice as loud.. it was only 1 sub before. But i turned the gain down a lil since its only 300 watts instead of 400. If i put it all the way up wont it send a clipped signal and that would be bad i assume. What should i listen for? People are hitting 150 Dbs, if i hit 100 it sounds like they are gonna blow, idk the diff between too much and just really loud.
Username: Hittin1
Post Number: 1213
100 decibles is barley above a wisper..
so it was the wiring.... thats the usual suspect...especially in low power system, where you are not as likely gonna blow subs with such little power... Unless they are really low wattage/quality subs and clipping their signal tring to more outta them that is possible.... Does that make sense?
Post Number: 121
yea im more worried about under powering them and pushing the amp too hard, so then it will send a 400 watt signal when its only capable of sending a 300 watt. so it will b clipped, if u understand that.
Im sure they will be fine, im sending them 300watts each, they are 400rms. And ive got the gain down to like 3/4, but i use the remote bass knob and i turn it all the way up.
Username: Hittin1
Post Number: 1214
There is sooooo many incorrect statments in that post^^^
1st
"yea im more worried about under powering them and pushing the amp too hard"
U cannot hurt your subs by underpowering them.... Otherwise you would damage your subs every time you turned the volume down..
2nd
"so then it will send a 400 watt signal when its only capable of sending a 300 watt. so it will b clipped,"
Your sub does determine how much power is being drawn from the amp (with exception of ohm load) in the form of a clipped signal..
In other words the subs recieves a clipped signal(determined by the amp and h.u., ect) and does not draw a clipped signal by simply being a higher rms rating than the amp.
You amp is gonna send whatever signal it's told to (by it's and the h.u.'s setting. This is a general statement, as there are other determining factores that play some role in a clipped signal..
I hope that makes sense to you.... I kinda confused myself..lol
another example..
If you were to take that 6oo wrms amp and try to push my Solo X (d2) sub-2500 wrms.. That sub is not gonna try to draw 2500 wrms outta that amp..... It gonna play whatever signal the amp tell is to..
lol
