Bronze Member Username: Sql_lover101Post Number: 13 Registered: Aug-08 | with 1 fi Q its cheap and u wouldnt have to upg electrical, is it worth ugprade.. n paying alot for 2 fi Q 15's? does it really make that big of a diffrence? or would 1 do just fine? and how much dual ohms u would get and what amp would u run? also wut components run good with this sub |
Gold Member Username: Andrew571Stillwater/Edmond, Oklahoma USA Post Number: 1972 Registered: Oct-05 | thousands of dual ohms. you get them. |
Bronze Member Username: Sql_lover101Post Number: 14 Registered: Aug-08 | ummm ok |
Bronze Member Username: BrewskyPrince george, British colu... Canada Post Number: 91 Registered: Aug-08 | ok here it is easy and you should just folow the instruction if it is duel 4 ohm or dual 1 ohm get the kicker zx1000.1 if you are going with duel 2 ohm get like memphis mrd1000.1,memphis prd1000.1, rockford 1000db, rd 1000.1 etc! |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18051 Registered: Jun-06 | Do you have the room for two 15's? LMAO Drizzle. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18052 Registered: Jun-06 | They only come in dual 1 or 2 ohm. |
Bronze Member Username: Kingandsons07Lincoln, TEAM RD USA Post Number: 54 Registered: Aug-08 | 2 15" dual 1ohm Q's on a RD 1750.1. wire it to one ohm and ![]() |
Bronze Member Username: Sql_lover101Post Number: 16 Registered: Aug-08 | is it worth getting 2 15 fi q's and paying the extra money plus to upg electrical? or is 1 good enough in a corolla? and why speaker components woudl go perfect with them? i got 6.5 n 6x9 |
Bronze Member Username: Kingandsons07Lincoln, TEAM RD USA Post Number: 55 Registered: Aug-08 | it is worth upg electrical if your keepin your car for a good time |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18053 Registered: Jun-06 | You will be happy with only one but it's your money and it never hurts to upgrade your electrical. For 2 Q's you would need at least 6 cu's ported. Do you have that kinda room? |
Silver Member Username: Imalik15 SI Mag9.1=Boom, New Jersey Jerzee Playa Post Number: 621 Registered: May-06 | You will be fine with 1Q..I have 1 15 Q Im very happy with the output. |
Bronze Member Username: Sql_lover101Post Number: 17 Registered: Aug-08 | i think think the cargo volume is 13.60 cu ft... if thats what your asking also what speaker components would be perfect? i got a 6x5 and 6x9 speakers |
Bronze Member Username: Sql_lover101Post Number: 18 Registered: Aug-08 | and do i need to upg electrical with only 1? what happends if it keeps dimming |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18054 Registered: Jun-06 | The big three will help with that but it never replaces a proper charging system. The Q is rated for 1000w and MOST stock electrical systems are ok with this. Depending on your usage and stock alt/batt a lot of ppl will say to run with what you have. I would start with the big three and go from there. With 2 Q's you will have to address your alt, wiring and possibly the battery. Do you know what size alt you have now? |
Bronze Member Username: Sql_lover101Post Number: 19 Registered: Aug-08 | how much to upgrade big 3? im not sure wut sz my alt is... but i kno when i had 2x12 jlw3 my lights would dim and i had it on 500/1 jl amp. if the bass was loud and i turned it up high it would cut off at times.. but what components do yall recommend |
Gold Member Username: Snowball123West Allis, WI United States Post Number: 1019 Registered: Oct-07 | the big 3 is just wire, i forgot what goes where, but for some components,I would recommend diamond audio. I love my Hex's. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18060 Registered: Jun-06 | http://www.s10forum.com/forum/f27/big-three-big-3-upgrade-how-to-321309/ It's a link to a big three done to a truck but the concept is the same. |
Bronze Member Username: Sql_lover101Post Number: 21 Registered: Aug-08 | Wut bout components what should I get to match perfectly with the q |
Gold Member Username: Hittin1Lake Charles, La. United States Post Number: 1229 Registered: May-07 | Jimmo.... what vehicle are we talking about? |
Bronze Member Username: Sql_lover101Post Number: 22 Registered: Aug-08 | 2004 corolla le |
