Need advice on a new receiver! Pls help nalin!!!
Username: Diesiel
Post Number: 56
Hi guys my patec blew up (was running 2700 puff) so i need to get a new receiver. I watch 119 61.5, is c00lsat 6000 premium any good? Please advise guys.
Username: Eatfish111
Post Number: 437
no co0lsat 6000 is not very good bad support
when buying a new receiver you have to figure out what you want it to do.
do you want a pvr?
high def?
read read read.
check out the sonicview 360 series
conaxsat series of receivers
if you want iks check out nfusion and k-box.
Personally I would go with the sonicview a well tested receiver with great support.
be sure to buy a new receiver that has usb capabilities.
Username: Diesiel
Post Number: 57
Thats the thing. I dont need anything too special (or expensive)just something that works and is bit newer than a shitty pantec. lol
Post Number: 438
captiveworks 700
cnx mini
pansat 250
Username: Saqeeb9000
Post Number: 3813
As mentioned by eat fish all the ones are top on good ,
my choices from top to bottom are
NFUSION (best support) u need internet connection.
viewsat (good support
sonicview (if u wanna go for pvr)
conaxsat (cheapest yet reliable)
