New member Username: AbbasulaimanDearborn, Mi Usa Post Number: 1 Registered: Sep-08 | Since I moved to my new house, my pansat 3500 is giving me good signal but the quality is zero, the reciever was doing well before I moved |
Gold Member Username: PrfrmnjPost Number: 2878 Registered: Oct-05 | Verify the alignment of your antena. Is it the same system you had at your old house? Basically, you need to post more information in order for anyone to help you! |
Silver Member Username: MuchoPost Number: 583 Registered: Dec-07 | abbas sulaiman Your Latitude 42.3*N Longitude 83.o*W Align your dish to these settings below. Satellite Look Angle For EchoStar 10/11 @ 110.o*W Satellite Look Angle For EchoStar 7 @ 119.o*W |
Gold Member Username: DoreenakadjOntario Canada Post Number: 1875 Registered: Dec-06 | Prfrmnj WB ... how are you? .. long time no see. how's the baby? I seen your post about the pic I posted of nalin in the thread that got deleted .. ya like it eh? I just couldn't resist or help myself. MY BAD HEHEHE |
Silver Member Username: MuchoPost Number: 585 Registered: Dec-07 | Doreen I didn't see the picture. Can you post it again? Which one is Nalin? ..... |
Gold Member Username: DoreenakadjOntario Canada Post Number: 1877 Registered: Dec-06 | https://www.ecoustics.com/electronics/forum/home-video/511875.html you can find it here in the link but I changed a few things on it this morning LMAO I can be such a brat at times !!TEEHEE!!! |
Gold Member Username: RtapFL Post Number: 2249 Registered: Jan-07 | also check your switch if you are using any.if you did not turn off receiver when relocating it you may have blown your switch.and also check your settings in antenna setup.sup prfrmnj and doreen |
