36" fortec satellite dish and 118.5w
Username: Jet9508
Post Number: 36
is 36" fortec satellite dish with 4 universal lnbs work for 118.5w and 110, 121, thanks
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3545
jet lee
Explain Universal LNBs?
Username: Tapeman
New York City in-HD, NY
Post Number: 3316
I think yo meant quad poalrity Universal LNB
If that's what yo meant
Quad polarity & 36" dish work on all N. America Ku band
Username: Mucho
Post Number: 560
(Quote=jet lee)is 36" fortec satellite dish with 4 universal lnbs work for 118.5w and 110, 121, thanks
Your Dish is OK only it will not work on all North America Ku bands.Such as
Videoguard
Irdeto 2
Viaccess
PowerVu
Diqicipher 2
Username: Nydas
Post Number: 11453
jet lee has "4 universal lnbs"
He probably has one Universal LNB on 118.7(and 119) and the other two are standard ones accessing 110, 121.
jet lee: Please post details, as this is the set up most people would or should be heading for soon except perhaps 121 not needed and 92 needed. Details of any bracket modifications, etc will be appreciated.
Username: Jet9508
Post Number: 38
I found this dish for sale in kijiji for $80, he said its good for internation channel like 97w, no other detail. thanks guys
Username: Jet9508
Post Number: 39
here is the link,
http://toronto.kijiji.ca/c-buy-and-sell-electronics-36-Fortec-Star-Satellite-Dis h-4-Universal-LNBS-Bracket-W0QQAdIdZ70612765
Username: Nydas
Post Number: 11461
You got a good buy, because you are getting a lot of channels.
Are you also getting 119W (Echo 7) channels?
Username: Plymouth
Post Number: 3549
jet lee
97 use a universal linear LNB, Bev an Dn use a cicular LNB, you cant use 4 universal LNBs.
Username: Jet9508
Post Number: 40
I haven't got it yet, just want to make sure I can use it. so is this mean that dish can use only on 97w, or any else?
Username: Plymouth
Post Number: 3554
No this dish can get many satellites with good LNBs and a multi LNBs bracket.
You can buy a motor and a Invacom QPH-031 Universal Linear/circular LNB, but you need to be a pro for aligned this dish.
With it you can get over 10 satellites with appropriated receiver
Username: Jet9508
Post Number: 41
I just bought a 36" dish with digiwave lnb, for 118.8 and 119 satellite, but the lnb couldn't locate any bird, I put the old lnb up and it can locate 110 and 119 without any problem. will it be the lnb problem?
Username: Plymouth
Post Number: 3589
jet
setup from digiwave
SETUP INSTRUCTIONS
Using a 30-inch or larger dish, aim with the following settings:
For DGL-1189S you should setup as below will better:
Satellite Name: 118°W (Anik F3) or 119°W (Echo7)
* LNB Power: ON
* LNB Type: Universal
* LNB Frequency: 9750Mhz/10750 MHz
Finally, do an AUTO SCAN or a BLIND SCAN
For DGL-1189D and DGL-1189Q you should setup as:
* LNB Power: ON
* LNB Frequency: 9750Mhz/10600 MHz
You can try on standard and 22Khz set on "ON"
I hope that help you
Username: Jet9508
Post Number: 42
but from my viewsat setup, I don't see any signal bar with the digiwave lnb, maybe they gave me bad lnb. when I put the old lnb up no problem get signal from 119w.
Username: Plymouth
Post Number: 3593
Jet
try on standard LNB and 22Khz set on "ON"
Username: Jet9508
Post Number: 43
when I use standard lnb, it locate 119w alright. after I switch to new lnb it just has no signal at all, I spent 2 days play around with it, still no luck. any help?
here is what i did.
36" dish with standard lnb, 119w works fine.
switch to new lnb, my viewsat show no signal bar, change lnb freq to 10600, scan, no channel. did I miss something.
Username: Bazzoon
Post Number: 27
jet lee, when you say it does not work you need to explain what setting in your setup page when you have the new LNB mounted. Only this way people can give you meaningful instructions.
Regards;
Username: Jet9508
Post Number: 44
after setup the dish
I go to viewsat antenna setup, echostar 7
lnb power on
try lnb type standard and universal
lnb high 10600
22khz off
tp freq 12224
diseqc 1.0 none (use only one lnb)
motor off
legacy sw none
one thing I notice strange is I have another old ecllipe dish lock to 119w, when I look at the compass it show 250', the new 36" dish show 240', it point at different direction,
Username: Plymouth
Post Number: 3624
jet lee
Do 2 scan 1 on 11250 and 1 on 10750
Username: Bazzoon
Post Number: 28
did you try 22khz on?
Username: Jet9508
Post Number: 45
I manage to get 57 channels from 119w, still no luck with 118.8 yet. about the dish aiming, why two dish point 10' different for 119w?
for 118 i use echostar 9 121w
lnb power on
lnb type universal and standard
lnb high 10600
lnb low 9750 and off
tp freq 11715
from channel scan I delete all old freq and put in new one 11715 ,11720 etc
and auto scan
no channel come up.
Username: Plymouth
Post Number: 3628
Jet Lee
you dont need to scan with 121W
Do 2 scan on 119W 1 on 11250 and 1 on 10750
Username: Jet9508
Post Number: 46
I though I have to use 121w setup for 118.8w and scan, I tried 11250 and it wouldn't work on 11250 because the lnb will not work on 11250,
I think I know the problem, not enough signal from the new digiwave lnb. the old standard lnb have much more signal for echo 7. the digiwave have only 26 signal bar. and the old lnb has 80. don't understand why, maybe I should try other brand lnb.
Username: Plymouth
Post Number: 3631
Jet Lee
Realign your dish with digiwave LNB, this LNB have different aiming.
