What Freq to use for 61.5 and 91
Username: Agf
Post Number: 87
Can anyone tell me what Frequency to use for 61.5 and 91 or 82. i the frequency 11250 for 61.5 ?
Appreciate your help.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3633
AGF
LNB Type Standard
LNB Freq:
61.5----11250
82------11250
91------11250
LNB Freq is very important if you want get all channels
Tp Freq
61.5---12355
82-----12224
92-----12224
Note: Tp freq is just there for confirm then you are on good satellite and have nothing to do when you do a autoscan.
Username: Agf
Post Number: 89
Thank you plymouth, will try this. Appreciate your reply
Username: Agf
Post Number: 90
Hello Plymouth,
I tried the freq and I got the channels for 91 W on each channel when I press the info button. I can see the follow but no picture, it says scrambles channel
Strength 73
Quality 72
lnb Freq 11250
Lnb tp 12326
, I have 2 dishes, I'm getting the channels on 61.5.
Any help on what I should do or what have I done wrong would be appreciated.
Username: Plymouth
Post Number: 3636
AGF
keep autoroll on and it comeback, that can take 10 minutes
Username: Cartier1
Post Number: 1995
AGF TRY TO SCAN THE CHANNEL TO SEE IF U ARE DOWNLOADING 91W CHANNEL . CUZ U MAY BE POINTING TO AN OTHER SAT EVENTOUGH U GET THE QUALITY . IF U SCAN AND U GET 91W THEN U RAE IN THE RIGHT TRACK. LET IT ROLL AND U WILL WATCH TV
Username: Plymouth
Post Number: 3637
Cartier is right check on channel 126 or 2126 if it is RDI
