How to grounded my satellite
Username: Meisha
Post Number: 45
HI
I purchased two ground blocks for me 3 Dual LNB that are connected to 2 receivers, and purchased a 8 feet metal rod and drove it into the ground,
Can anyone tell me or post a link how to to properly ground my satilles ?
Thanks
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3490
Meisha you does need a 8 feet metal rod , ground it on electric mat of house or existing ground
here is a link for grounding:
http://www.sadoun.com/Sat/Installation/Grounding.htm
Username: Meisha
Post Number: 46
do i have to put the ground block on all of my RG6 cables that are hooked up to my LNB's for each receiver (meaning 2 cables for bird and 2 cables for 110 and 2 cables 119.)
I have 4 out of 6 done. do i have to do the last 2 ?
Username: Kirankumar
NO Bashing
Post Number: 2934
just ground your switch and you should be ok
Username: Meisha
Post Number: 47
i am still loosing signal if i have both receivers on. after grounding my switch
Username: Plymouth
Post Number: 3492
Meisha
Does have you connected one switch for each receiver and one output of each LNB on each switch?
Do you have a Voltmeter?
If yes, on AC volt put one probe on RG6 cable nut and the other probe on receiver case(cable unhook), give me voltage if it there
Username: Scabz
Knoxville, Tn Us
Post Number: 410
I never grounded my dish. It's been a few years and not a prob.
Username: Plymouth
Post Number: 3543
scabz
With a motorized dish and scanning on low gain satellite, it is better, but on standard small dish, no need, if it is lower then electric mat
Username: Meisha
Post Number: 48
No i do not have a volt meter,, is there another way i can do it ?
i have asked my friends for one and they do not have one either,,
Username: Plymouth
Post Number: 3546
Meisha
Try to power your 2 receivers on same power source with a extension cord and check if it work now
Username: Tapeman
New York City in-HD, NY
Post Number: 3317
- Grounding has nothing to do with signal gain or loss
- Grounding is to prevent electronics devices inside the house from static electricity or lightning
- Good coax connectors and RG-6 coaxial cables are the keys for great satellite signal
But I think yo got a problem with Pansuck due to damaged components in yor receiver
I'm not sure if it was yo or a similar name who had conflict with 2 receivers one of them was Pansuck
Try 2 different receivers see if this problem goes away
I usually test one cord at a time to make sure it works well before connecting to switches or LNBs
Username: Mucho
Post Number: 564
Meisha, Can anyone tell me or post a link how to to properly ground my satilles ?
Maybe this will help.
Username: Plymouth
Post Number: 3550
King
with my system, i test with and without and i have better quality with ground, interference can affect signal.
Tested and confirmed
Other thing, electric power in house on 240 volts with neutral split 2 120 volts if neutral is inverted, that can produce a voltage non wanted.
Username: Meisha
Post Number: 49
Plymouth and everyone,
I have gotten both of my receivers working now and i am able to have both of them on without loose signal on any birds,
I had to default both of my receivers to resolve the issue and replace one of my switch..
hopefully i am out of the wood works with the signal problem
Username: Plymouth
Post Number: 3556
If i understand well, it work now?
Username: Tapeman
Post Number: 3320
"Other thing, electric power in house on 240 volts with neutral split 2 120 volts if neutral is inverted, that can produce a voltage non wanted."
I think yo got AC concept totally wrong
AC electronics known as alternating voltage and current
Voltage is the potential difference
Inverting low freq 60 cycles per second AC is irrelavent
240V is +120V and -120V constantly alternating
positive becomes negative and negative becomes positive
But one of them is Hot other is Common
With use of ground it forces current return thru earth (ground)
Splitting potential differnce in half
Half the energy, half the power and grounding the common negative return
Even if yo use 240V
Yo still need ground
To protect load devices
And grounding has nothing to do with signal gain or loss
Even if yo had yor microwave on
Grounding is like I described above
Regardless of yor experiments
Satellite signal even after down converting is still very high frequency
Low freq has no significant interference
Other interfences are due to other high electromagnetic waves in the air
Shielding signal (as in RG-6) is to prevent lumping other undesired electromagnetic waves
Shielding and grounding are 2 different things
Username: Plymouth
Post Number: 3601
King
I conceived many control panel for the industry on 600, 550, 380, 208 volts 3 phases
and many on 240 and 120 volts, if my concept is totally wrong.
I,m electrician, electronician and electro-thecnician with it.
I conceived many ligth system for discotheque.
I conceived many drive motor system
I conceived and modified many sono
amplifiers
And many more
Username: Mucho
Post Number: 573
Look you too
The incoming electrical service to a person home as a rule is 240 Volts or less
which is 4 conductors A and B phase,
a neutral and a bare grounding conductor.
The neutral will carry the unbalance load
between A & B phase to ground.
All the above has nothing to do with
equipment grounding.
Electric takes the shortest path to Earth.
That is the reason the National Electrical Code requires
the service to be grounded by a driving ground rods
and on the cool water supply conduit
just as it enters your home if the incoming water supply is copper conduit.
If lighting or the Power Compony's
Transformer shorts out
and the incoming service is not grounded as per the NEC
it will send High Voltage in the home and will be like the 4th of July
Username: Plymouth
Post Number: 3604
"The incoming electrical service to a person home as a rule is 240 Volts or less
a neutral and a bare grounding conductor."
240volts 1 phase 2 conductors and ground
440volts(USA)600 volts(Canada) 3 conductors and ground is for 3 phases(1 phase to ground give 380 volts use on fluorescent lighting in Canada)
A and B phase does not exist
Username: Mucho
Post Number: 575
Plymouth
In Canada what electrical code do you people follow?
You say that the Electric Powder Company of Canada supply a home with only 3 conductors two hot and one ground?
You mean to tell me that an equipment ground is not required?
When the incoming service is connected to a single phase main electrical panel
in a home here in the USA the conductors
are color code as per the NEC Black, Red and White. As per the NEC Black is connected to the first lug of the main panel which is A phase, Red is connected to the second lug which is B phase, White is connected to the ground Bar,
and the Bare conductor is connected to the equipment ground Bar.
Username: Plymouth
Post Number: 3605
White
240 volts wiring is identical in USA and Canada
The shematic i shown is from Electric Provider to Meter
In breaker panel ground is tap on White, red and black are 2 X 120 volts taps
240 volts work on only one phase, and not phase A and B, but tap A and B
1 phase is a alternate wave 0 to +240 to 0 to -240 who give 360 degrees
In 3 phases each phases is shifted with 120 degrees
I hope you understand difference btw phases and Taps
Username: Bjcrisp6478
Post Number: 211
i don't have mine grounded and it's fine....why would i want to ground it ???? there a reason?????? thanks
Username: Tapeman
Post Number: 3321
I didn't want to start an AC battle
I do respect everyone's view
I was only responding to inverting AC voltage statement
Plymouth is right about multi power phase
And it varies from one country to another
Even from one town to another
I agree with Hawk on one thing only
"Electric takes the shortest path to Earth."
I think what yo meant is:
Electricity takes the shortest path to earth
Plymouth
I'm going to give yo correct concept on multi-phase
My 27 years of experience can allow me to write my own book on basic fundamentals of Electricity and Electronics
Yo take an electric current around a metal core (transformer) thru insulated conductive wires
The core becomes intensified
Yo wrap another set of wires around transformer (as coil) and it will induce another electric current around new coil with polarity depending on its direction totally independent phase
yo can step and repeat with another set of coil
THAT'S MY THEORY ON 3 PHASE
They can be cascaded for electrical equipment that requires 3 phase
Username: Mucho
Post Number: 576
True we have either a single phase or a three phase incoming service provied by the Electric Power Company.But here in the States we comply to the National Electrical Code.We identified each
conductor as a phase not as a tap
only as a A, B, or C phase as per NEC.
I think that enough is enough on this thread, time to put it to bed
Username: Plymouth
Post Number: 3606
King
Sorry you are not right, you cant create a new phase with a transfo, but a isolate tape on same phase
Look it
You can created a new phase only with a Rotophase or a electronic motor drive, which transform AC to DC and create 3 phase
2 phases exist only on AC motor and the second phase is created inside motor coil and capacitor use for start the motor with centrifugal switch
White
This is a transfo who explained how have 120 volts 1 phases from 3 phases use when 240 volts 1 phase not available, not use for private house.
I hope now you, King and White understand now, how it work.
Username: Rekman
Mntl-Quebec-...
Post Number: 402
PLYMOUH HELP ME MY FRIEND.
I want to kno if I change my Receiver, should I also change my LNB?? (i have one which i 118-119)....
Or would I be able to use the LNB on any new rreceiver which i will buy..
please help
i also need a calculator how to poit my dish... because i change my dish position... tell me how to calculate the pointing...
Username: Plymouth
Post Number: 3608
MKM i give you answer on your thread
https://www.ecoustics.com/electronics/forum/home-video/511723.html
