110 signal is taking over VS Ultra receiver
Username: Letschill247
My friend has a VS Ultra :
LNb Type: Standard
LNB Freq: 11250
22KHz : Off
And it's the 500 di*h 2 Lnb (110& 119) & 1 Lnb (61.5)
So when he is trying to setup the Antenna for the different satellites (119, 61.5 & 110) the only thing that shows is the 110 signal on all sat's. he tried to connect only 119 & 61.5 to the switch and both sats show up with no problems , but when 110 is connected that's when all sat's shows 110. Another way we've tried turn off the 110 LNB then 119& 61.5 are visible. Please advice & thanks guys
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3532
Try another switch or use 110 on port 4
he actually ordered a new switch still same issue. on the 110 wire there is a ground wire attached to it ,but the ground wire is not connected to anything.
Username: Plymouth
Post Number: 3536
Which switch you use
Picture or link please?
Post Number: 7
Plymouth, I'll look at it when my friend comes back and I really thank you for your help.
Username: Plymouth
Post Number: 3555
Fresh Puffs
You are Welcome
Username: Bouttep
Post Number: 68
i have the same problem my 110 dish gives 99-100% quality , but 119 dish gives me 0 % , when it does give 30-40% it's 110 coming up , i changed the switch and still nothing , any idea i have a sonicview 4000
Username: Plymouth
Post Number: 3574
Joe try a factory default and reload last bin and rescan all sats
Username: Saqeeb9000
Post Number: 3794
"joe damas
Username: Bouttep
Post Number: 68
Posted on Sunday, August 31, 2008 - 02:39 pm: ""
menu anteena setting, change ur lnb to 12256 etc..
Username: Plymouth
Post Number: 3577
Sada and everybody
Tp freq is only there for display if you are on good satellites
and do nothing on scan, if the setting is good you can scan.
Just info to help you.
Post Number: 8
plymouth, it was the LNB issue. when we chanted it every thing is working fine. thanx
Username: Plymouth
Post Number: 3602
Fresh Puffs
Good news
It seems many 119 LNB on market are defect.
Which model and brand?
Post Number: 9
I'll let you know once I go back to my friend's house.
Username: Pannu16
Post Number: 778
Scan ur sat fresh puff without 110 connected. MAke sure u have right DISEQC switch for all lnb.
once u scan everything then connect 110 and scan that.
try it and it shud b all fine. try it and reply.
