Silver Member Username: Top2000doggPost Number: 121 Registered: Jul-07 | I have a problem with my receiver my nephew dropped it, and it hit the floor not that hard but now it won't turn on. what can I do to get it working again???? if you need to know the brand its megasat yt6688 thanks any help will be appreciated! |
Gold Member Username: DoreenakadjOntario Canada Post Number: 1802 Registered: Dec-06 | First off sorry about your luck ... and are there lights working on the reciever at all eg: clock . When attempting to turn it ON, are you pushing the front on/off button? Try the remote on/off button see it that works. Plus make sure the back switch is ON not off. If none of the above work for you you could try to open the receiver box and see if the on/off switch wires are connected properly. Other than that you could take it to a repare shop or just get a new UPDATE receiver. My choice would be sonicview 360. |
Bronze Member Username: JustforhahasPost Number: 43 Registered: Jul-08 | Consider it a blessing, since that Pansat 2500 clone has seen better days. All you can do is open the casing and check for loose conections or the fuse. Its a dinosaur and not worth spending any money to fix it. I agree, a Sonicview 360 series, would be my next option. |
Silver Member Username: Top2000doggPost Number: 122 Registered: Jul-07 | the lights don't turn on and I checked the inside nothing is loose and everything looks fine any other suggestions? and where is the best place to get a sonicview 360? |
Silver Member Username: DimwittPost Number: 844 Registered: Aug-06 | a place : http://cgi.ebay.com/MFG-WARRANTY-SonicView-SV-360-Elite-PVR-SV-360-FTA_W0QQitemZ 110280402032QQihZ001QQcategoryZ32847QQtcZphotoQQcmdZViewItem |
Gold Member Username: RunnerguyPluto Post Number: 1512 Registered: Sep-06 | another place: |
Silver Member Username: Top2000doggPost Number: 123 Registered: Jul-07 | which one is the best? |
Gold Member Username: RunnerguyPluto Post Number: 1514 Registered: Sep-06 | There are a number of people in this forum that would agree that southcoast is solid, secure and safe. I'm sure Tooter wouldn't steer you wrong. I have nothing to gain by telling you about this place. There are a lot of peoplein this forum that would tell you that hell is a great place. |
Silver Member Username: Top2000doggPost Number: 124 Registered: Jul-07 | thanxs but what I meant was which receiver is the best which sonicview receiver? and do they all operate the same or is it different? |
Silver Member Username: Top2000doggPost Number: 125 Registered: Jul-07 | I need to know some info. on the sonicview 360 which is the best one the premier of the elite? does it work with the dish 500? does it work similar to the megasat? |
Silver Member Username: Top2000doggPost Number: 126 Registered: Jul-07 | anyone know how to get a device for helping me point the dish? |
Bronze Member Username: PotshotPost Number: 24 Registered: Nov-06 | Dude just get your post perpendicular to the ground. Check it with a cheapie bullet level all the way around. Set your skew,elevation and rough in your azimuth on the dish based on your zip code listed in the guide at this link. Click on "Learn more" http://www.dishnetwork.com/content/our_products/installation/index.shtml Then rotate the dish slightly left and right until you start getting signal on both LNBs. You might have to do some tweeking to get it maxed out but its not rocket science. I have a camouflaged camping dish on a wooden sled that I set up in the desert all the time and I just eyeball it and have I have it tuned in a few minutes. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 3339 Registered: Jan-08 | Sean Use these sites for aimed your dish Buy a cheap satellite tracker as this one http://sadoun.com/Sat/Products/Accessories/Meters/SF95L-DSS-FTA-Satellite-Signal -meter.htm Good luck |
Silver Member Username: JjgeePalatine, IL USA Post Number: 102 Registered: Apr-08 | Plymouth..................Spam Naughty................Naughty |
Bronze Member Username: JustforhahasPost Number: 49 Registered: Jul-08 | Plymouth runs and whines to the adnins about spams, and then thanks the admin when he deletes the spam. Now Plymouth begins posting his own spam , along with Nalin Nydas converted 2500 sites and their spams, and thinks thats OK. What a hypercrite! another 2 faced wannabee, king of Zoocoustics! |
Silver Member Username: Top2000doggPost Number: 127 Registered: Jul-07 | so which sonicview 360 is the best the premier or the elite? any recommendations? |
Bronze Member Username: JustforhahasPost Number: 50 Registered: Jul-08 | The Elite is more functional, because it has a dual tuner, allowing for watching 1 channel while recording (PVR) another 2nd channel. The Premier is a great receiver also, but has only a single tuner and you can only record (PVR) what you are watching. So you decide what which you prefer. Reading at other forums would have explained this all to you. This place is really not the place to get "educated" about FTA. This site is basically for wannabees' and haha's. |
Silver Member Username: Top2000doggPost Number: 128 Registered: Jul-07 | does the sonicview operate the same way as the megasat(pansat clone)? what I mean is the bin loading and those types of things? |
Silver Member Username: Top2000doggPost Number: 129 Registered: Jul-07 | does the sonicview operate the same way as the megasat(pansat clone)? what I mean is the bin loading and those types of things? |
Bronze Member Username: JustforhahasPost Number: 64 Registered: Jul-08 | Its like driving a car, basically they're all the same. The brakes, gas pedal and steering may react a lil different but otherwise its the same. If you can use a remote control, then thats as smart as you need to be. FTA receivers were not made for rocket scientists, nor were DTV , Bev or DN receivers. Any Joe Blow on the street can operate any receiver. |
Silver Member Username: Top2000doggPost Number: 130 Registered: Jul-07 | thanx for the info! i had another question, how do you connect two receivers to the satellite without a cable splitter? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 3375 Registered: Jan-08 | Sean We need to know, how many LNBs? Cable splitter does not work |
Gold Member Username: DoreenakadjOntario Canada Post Number: 1825 Registered: Dec-06 | Sean akins.. the option to Jtag you magasat is still available to try . Download Megasat Easy Jtagging, jtag repair-kit for megasat yt6688 here is a link dss tester.com/details.php?file=3381 oh and on ebay you can find the jtag stuff you'll need http://search.ebay.com/2500a_W0QQfcclZ1QQfclZ3QQfsprZ0 this is what jtaging can help with 1. YOUR RECEIVER SEEMS TO BE DEAD ? 2. IS IT DEAD ? 3. YOUR RECEIVER DOES NOT TURN ON ? 4. IS YOUR RECEIVER FLASHED WITH A BAD/WRONG FILE ? 5. YOUR RECEIVER DOES NOT POWER ON ? 6. YOU CANNOT FLASH YOUR RECEIVER ? 7. YOUR RECEIVER ONLY DISPLAYS WEIRD NUMBERS ? 8. IS YOUR FILE CORRUPTED ? 9. YOU HAVE A NIGHT RIDER? with jtaging you can fix your problem ( maybe ) but you could give it a try . i hope this can help you out . Good luck |
Bronze Member Username: PicanhaEast LA Post Number: 47 Registered: Jun-08 | This one may make it to the complaint thread!! |
Bronze Member Username: JustforhahasPost Number: 78 Registered: Jul-08 | Don't even condider Jtagging a megasat POS, its not worth the time and effort. |
Silver Member Username: Top2000doggPost Number: 131 Registered: Jul-07 | why? it doesn't work? |
Silver Member Username: Top2000doggPost Number: 132 Registered: Jul-07 | if anyone is out there with sonicview 360 premier please make yourself present so that I can ask you some questions |
Silver Member Username: Top2000doggPost Number: 133 Registered: Jul-07 | if anyone is out there with sonicview 360 premier please make yourself present so that I can ask you some questions |
Silver Member Username: Top2000doggPost Number: 134 Registered: Jul-07 | which bins are better? the puff or b75? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 3478 Registered: Jan-08 | Sean buy a viewsat or Captiveworks much better support Read it on support: https://www.ecoustics.com/electronics/forum/home-video/509951.html I have both, you can trust me, i'm very satisfy. Ask Nalin on new thread for puff or b75 one of the most on it. |
Gold Member Username: DoreenakadjOntario Canada Post Number: 1838 Registered: Dec-06 | Sean here is are links to compare the SV FTA receivers Prices may vary depending on where you buy one... these links are just to compare the receivers. Unless you wish to buy one from that site/dealer. The choice is up to you. If you wish to but one Ebay is a good place to start looking around. |
Gold Member Username: DoreenakadjOntario Canada Post Number: 1839 Registered: Dec-06 | oh and to answer you question about PUFF or b75... Puff is an upgrade from b75 I find it more stable but thats just me. I like Puff myself. I have a FLU/Fortec converted into pansant PUFF. If you do want to get your Magasat up and running , Jtag is the way to go and I can help you convert it to Puff . I have done it b4 for friends with Magasat ,Multisat and Fortecs also. I dont just post bin files for anything I actualy work on the recievers too. |
Bronze Member Username: KayossPost Number: 70 Registered: Feb-08 | Doreen, you really are a helpful princess, but I think you are wasting his time. |
Gold Member Username: DoreenakadjOntario Canada Post Number: 1840 Registered: Dec-06 | Kayoss... don't you mean wasting my time ... LOL |
Bronze Member Username: KayossPost Number: 71 Registered: Feb-08 | You're right, yours, his and now mine too! |
Silver Member Username: Top2000doggPost Number: 135 Registered: Jul-07 | so what is the best receiver? |
Bronze Member Username: AgfPost Number: 84 Registered: Aug-06 | I would suggest the captiveworks. Buy the cheaper model, if you get it to work for a year it great. by then a new model will be out. |
Silver Member Username: Top2000doggPost Number: 136 Registered: Jul-07 | so captiveworks is the best receiver?! any others or better ones?!?!?!? |
Silver Member Username: JustforhahasPost Number: 214 Registered: Jul-08 | Sonicview 360 Premier Sonicview 360 Elite Viewsat Ultra Viewsat Ultra Lite Conaxsat Mini Conaxsat Duo Nfusion Nova I believe these all to be better than any Captiveworks, in all possible ways. |
Platinum Member Username: NydasPost Number: 11469 Registered: Jun-06 | Agf has a good point. with Nagra 3 coming in and the uncertainties associated with the industries ability to cope with new software, a smaller investment in a cheaper Captiveworks model now is the best solution. |
Silver Member Username: JustforhahasPost Number: 218 Registered: Jul-08 | No point in buying a cheap non USB ready receiver or ANY receiver if you are worried about NEVER having TV again because of Nagra3. Either buy a GOOD USB ready receiver or NONE at all..that SV Premier is only $135...why waste $100 on a cheap receiver, if none are going to work...spend a few more dollars and get a USB ready receiver.. |
Platinum Member Username: NydasPost Number: 11473 Registered: Jun-06 | justforhaha's aka LK has a vested interest in your buying a new and expensive receiver. Everybody knows that Nagra 3 is being tested and will become the encryption in a couple of months. We WILL then have a blackout for about 1- 4 months and there is no point sitting on an expensive investment during that time. The other thing to note is that Nagra 3 will most likely be exclusive to HD - i.e. when the appropriate time comes they will activate "HD only" part of the software. If you are planning to invest more money then you should get a HD receiver and be prepared for the blackout I mentioned above. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 3568 Registered: Jan-08 | I agree with Nalin A CW 650S, 700S or Viewsat Ultra Lite two best support receiver non IKS |
Silver Member Username: JustforhahasPost Number: 223 Registered: Jul-08 | nalin...just babbles nonsense, about things she has no crystal ball for.. |
Platinum Member Username: NydasPost Number: 11477 Registered: Jun-06 | justforhaha's aka LK GO TAKE YOUR MEDICATION |
Silver Member Username: Top2000doggPost Number: 137 Registered: Jul-07 | so sonicview is a good pic then? im listening to platinum and gold members for this since they have more experience, no offense to anyone else |
Silver Member Username: Top2000doggPost Number: 138 Registered: Jul-07 | how do you Jtag a megasat? any help to try and get my receiver running |
Platinum Member Username: NydasPost Number: 11483 Registered: Jun-06 | megasat yt6688 is a Pansat 2500 clone. whtever applies to Pansat 2500 clone receivers applies to your receiver. Look at these URLs. Important [link removed] Also look at [link removed] [link removed] [link removed] |
