Need subwoofer help with Denon AVR-788
Username: Esquire73
bought the receiver and hooked up my existing surround speakers...however, my existing sub is passive and won't work with the sub out on the receiver...any idea how to get this to work? tried using the "amp assign" function to run the extra power to "zone 2," and hooked the sub up, but got nada...any help would be greatly appreciated
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 1430
Yeah, that won't work, I don't think.
Even if it did, how would you control the frequency that is sent to the amp. You'd be sending the full range to the amp.
Username: Esquire73
yeah, was going to try to use the receiver's crossover function, but just went ahead and bought an active sub...sounds good...thanks
Username: Dmitchell
Post Number: 1461
What did you buy Fred?
Username: Esquire73
Sony SA-W2500...very economical, and sounds great for what I use it for (secondary system)...very happy with it
