Need help on 118 and 119
Username: Danny07
I got 31"*32" dish with 118&119 LNB but cannot get any signal, actually i easily locate 110 and 129 but couldnot get 118&119
can you plz tell me the reason i am in canada
Username: Solano2008
Toronto, Ontario Canada
Post Number: 26
i Have dish 1000 and cannot find 118 satellite. I am getting all the english channels but no indian channels
Username: Nydas
Post Number: 11463
CB2008A
This is the LNB for the new 118W (Anik F3 / 118.7W / 118.8W) satellite. With this special LNB, you can get BOTH 118 and 119 at the same time!
Works with both Free-to-Air and Original DN Receivers!
Requires: 30-inch or larger dish. 20' oval may work but is unreliable and YOU WILL MISS some channels.
Compatible with DirecTV, Free-to-Air (DiSEqC, 22KHz), and
legacy switches (SW21, SW44, etc)
Not compatible with DishPro switches and/or DishPro (stacked) LNB's
SPECS
Polarization: Circular
Input Frequency: 11.70 - 12.75 GHz
LO Frequency: 10.750 GHz
Noise: 0.5 dB
Dual-output (ready for 1 or 2 receivers). Each output will give you both 118.7W and 119W.
SETUP INSTRUCTIONS
Using a 30-inch or larger dish, aim with the following settings:
Satellite Name: 118A°W (Anik F3) or 119A°W (Echo7)
LNB Type: Standard (or Single)
LO Frequency: 10750 or 10600 MHz
Finally, do an AUTO SCAN or a BLIND SCAN
For some the following settings may work better or give you more channels:
LNB Type: Universal
LO Frequency: 9750 MHz
HI Frequency: 11750 MHz
ALTERNATIVE SETUP
The lnb is good for 118.7, but may not receive all channels/transponders for 119 as the highest frequency of the LNB is 12.2 GHz. The normal 119 LNB goes up to 12.70 GHz. According to lyngsat (http://www.lyngsat*com/packages/dish119.html) the highest transponder frequency in use now is 12.516GHz.
You may get around this by doing two scans. One with LNB frequency set at 10750 or even lower and then another scan with LNB frequency set at 11250. alternatively scan each one of the missing transponders of Echo 9 separately using LNB frequency 11250.
Username: Danny07
I tried but could not get do Ihave to skew dish little bit???
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3578
You need to skew if you have more then one LNB
Username: Danny07
I have only 1 lnb but i easily got 110 and 129 but not 118 or 119 can you plz help mewhat i amdoing wrong
thanks
Username: Plymouth
Post Number: 3580
Daniel
Try different Tp for get 118,119
Strong Tp is different on location you are
Username: Saqeeb9000
Post Number: 3795
plymouth is 30 inch dish a must to get 118.7 , i have 18" dish, i wanna buy lnb mentioned above , will it work for me?
and is this lnb also good for 110 .
Username: Danny07
Thanks plymouth for your help i will try, but not sure what I am missing:-))
Username: Plymouth
Post Number: 3583
Sada if you are located in 100-125 longitude west you can get 118-119 with 18"
I took 119 and 121 with my old 18" and motor but only few Tp(with my location).
If you buy a dish take 36" and HH-120 motor and QPH-031 LNB and get many many satellites
Yes it is good for 110, but put a bracket holder and add a standard circular LNB
