New Pansat 2700 NEED HELP!! THANKS!
Username: Farmrkid
I have a new pansat 2700 and was able to get some satellites set up. I can get the channel guide to come up, but all my channels are locked, with the exception of the free channels advertising the satellite companies. Any ideas?
Username: Satopia
Post Number: 221
do a factory reset then rescan channels it should get your channels bk with no lock on them
Username: Satopia
Post Number: 222
its kinda odd that those channels are locked and its new did you go in to the channel editing menu?
Username: Farmrkid
Last night I did a factory reset and rescanned the satellites. I am not 100% sure that I have the right ones, but I did see that I had good signal and quality, almost 90% if not better. When I do the scan, the channels list with a dollar sign beside them and I cannot view them. The screen says "bad channel or scrambled," or something to that effect. I also get a few channels without the $ sign and am able to view them, but they are the information channels, such as dish network information. Also, I get a channel called ANGL, I believe, and a few NBA channels. But, still no TBS or USA or the like. I am hooked up to a dual dish network and have the number one plugged into the pansat sat in. Any other ideas? I really appreciate the help.
Username: Satopia
Post Number: 223
check your switch out side to see what ports you have each lbn going to like echostar 7 port 1 and echostar 8,6 on port 2 and so on if these setting are not correct youll not get your channels also make sure you have the lastest bin file for 2700
Username: Satopia
Post Number: 224
also heres a step by step for you to go by
>>http://www.future-fta.info/Forums/showthread.php?t=42316
Username: Nydas
Post Number: 11467
With the new BINs for 2700, you have two types of switch settings in the Antenna setup -
1.0 - Ports 1,2,3 and 4 or None
1.1 - Ports 1 to 15 or None.
The port setting suggested by alton vann penny are usually related to 1.0
