Lost 119
Username: Bouttep
Post Number: 65
i'm having problem getting signal for sat 119 , i get excellent signal for sat 110 but , 0 quality for 119 . if disconnect antenna that's pointing 110 , i get low signal and when scaning , i don't get all the channels , and as soon as reconnect 110 i loose 119
did a factory reset , and same thing
can anybody help
Username: Tapeman
New York City in-HD, NY
Post Number: 3319
Make sure a working bin is used
List all yor antenna settings
List all yor hardware
Specify which receiver used, LNBs, brackets, switches, etc.
Make sure yo list
No stories
I'll get yo up and runing in seconds
As a guess
Without knowing yor detailed settings
I would say make sure yo skew second LNB
There is a setting for each zip code
Check this site for skew settings:
http://satcalculator.freehostia.com
Username: Bouttep
Post Number: 66
thanks king i'll try that and let u know
Username: Bouttep
Post Number: 67
can't seem to connect to the link you gave me , i'am in the caribbean any idea
