New member Username: Nydu_sPost : 15899 Post Number: 1 Registered: Aug-08 | Hahahahahahahaha was here Plymouth is Q ueer |
Bronze Member Username: CiscomxPost Number: 26 Registered: Jan-07 | Bin 287 for Pansat 2700A/E is out at ftabins.net |
Bronze Member Username: Sonia18Post Number: 15 Registered: May-08 | does anyone know how long this will work? |
Gold Member Username: Saqeeb9000Post Number: 3778 Registered: Oct-07 | sonia which rec u have? |
Bronze Member Username: DetPost Number: 72 Registered: Jan-08 | why isn my epg working for channls on anik f3 on my pansat 2700a?it works for every other echo that im using such as echo 7 and 8.10 but not anik it was working before. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 3537 Registered: Jan-08 | False Nalin Post number 1 Mnm start a new thread https://www.ecoustics.com/electronics/forum/home-video/35.html |
Bronze Member Username: Sonia18Post Number: 16 Registered: May-08 | i have pansat 2700. when i download the bin i just get the microsoft thing ..wat do i do? |
Gold Member Username: Saqeeb9000Post Number: 3782 Registered: Oct-07 | start a new thread and aky for nalin .. NYDAS . he knows in and out of pansat , he can help u better.. |
Silver Member Username: ZunnaPost Number: 270 Registered: Jun-06 | oh thank god sonia i'm not the only one ..i have the same problem and i keep on sayin that but no one helps |
Silver Member Username: MetallicaPost Number: 884 Registered: Jan-08 | Sonia...you need a Winrar to extract the bin. |
Bronze Member Username: Sonia18Post Number: 17 Registered: May-08 | and where will i get that plz help me out here? |
Silver Member Username: MetallicaPost Number: 885 Registered: Jan-08 | http://winrar.d0wnloadz.net/ |
Bronze Member Username: Sonia18Post Number: 18 Registered: May-08 | and i have to pay for that. is there anything else |
Silver Member Username: MetallicaPost Number: 886 Registered: Jan-08 | no you don't have to pay for it yet..it's a 40 days free trail. |
Gold Member Username: Saqeeb9000Post Number: 3784 Registered: Oct-07 | http://www.rarlab.com/download.htm try this and download WinRAR 3.80 beta 5 its free |
Bronze Member Username: Sonia18Post Number: 19 Registered: May-08 | it doesn't say that tho .. 2. saya membership options |
Gold Member Username: Saqeeb9000Post Number: 3785 Registered: Oct-07 | which one ? did u tried the link i posted.. |
Bronze Member Username: Sonia18Post Number: 20 Registered: May-08 | Sada it says its an excutible file it can harm my comp |
Silver Member Username: MetallicaPost Number: 887 Registered: Jan-08 | try this one. http://www.download.com/WinRAR/3000-2250_4-10007677.html |
Bronze Member Username: Sonia18Post Number: 22 Registered: May-08 | WinRAR 3.80 beta 5 .. this one |
Silver Member Username: ZunnaPost Number: 271 Registered: Jun-06 | it says the same thing in mine that its excutibe should i open it i hope it doesn't harm my computer |
Gold Member Username: Saqeeb9000Post Number: 3786 Registered: Oct-07 | try mettalica's one.. all of them should be same |
Gold Member Username: Saqeeb9000Post Number: 3787 Registered: Oct-07 | Executable From Wikipedia, the free encyclopedia Jump to: navigation, search This article needs additional citations for verification. Please help improve this article by adding reliable references. Unsourced material may be challenged and removed. (July 2008) This article is about a general type of computer file. For the specific file type used in some operating systems, see EXE. A Hexdump of a binary executable file A Hexdump of a binary executable file In computing, an executable (file) causes a computer "to perform indicated tasks according to encoded instructions,"[1] as opposed to a file that only contains data. Files that contain instructions for an interpreter or virtual machine may be considered executables, but are more specifically called scripts or bytecode. Executables are also called "binaries" in contrast to the program's source code. no it should be fine |
Silver Member Username: ZunnaPost Number: 272 Registered: Jun-06 | ok Sada i got it it says install and then it has Associte Winrar with and interface and stuff should i just click ok ? |
Bronze Member Username: AgfPost Number: 81 Registered: Aug-06 | I have 61.5 and I get the asian channels. however which satellite should I install so I can get the cricket. I'm insterested in the Indian/Pakistan/Sri Lankan cricket matches. Appreciate your help |
