Silver Member Username: JustforhahasPost Number: 180 Registered: Jul-08 | DN activated their new PID keys 0106 today affecting FTA and rom 102 cards..they using an old ECM for april 30, try using fixes from around them..or wait for new files. It appears we also have a Bev ECM in the stream as of 3:45pm EST. Bev is down on Sonicview and Pansats, but still up on Viewsats and Captiveworks.... Bev did change their secondary keys 0907 yesterday 27 August, but had NOT activated them then, but appears they have now.. Also DN changed their secondary keys 0106 today 28 August, using old keys from an old 30 April MECM, , so we have a DN ECM also. New DN (0106) Keys August 28, 2008 1:10 PM -------------------------------------------------------------------------------- DN (0106) Last update : Fri. Aug 28, 1:10 PM 86: C9 DC DB 84 5A B8 2C DF 7F 32 8D E5 21 5C 45 4E 96: 4E B1 A8 DA 2D 92 90 D9 E6 3C 5E CE E4 FE E3 86 New This key was used for the 4/30 mecm update. That mecm update is now back in the stream and so is this key SO WE HAVE A DN ECM NOW, AS WELL AS A BEV ECM |
Bronze Member Username: Sonia18Post Number: 13 Registered: May-08 | so i just put the keys in right?? there's new bin change? |
Silver Member Username: ZunnaPost Number: 269 Registered: Jun-06 | i put these in and it says searching or keys? |
Silver Member Username: JustforhahasPost Number: 182 Registered: Jul-08 | As of right now Viewsat and Captiveworks are NOT affected by either ECM. But, Sonicview and Pansat are down on BOTH Bev and DN.. |
Silver Member Username: JustforhahasPost Number: 183 Registered: Jul-08 | You cannot just input these keys, you need new files, or maybe old files from around April 30 may work.. |
Silver Member Username: JustforhahasPost Number: 184 Registered: Jul-08 | You cannot just input these keys, you need new files, or maybe old files from around April 30 may work on DN.. |
Gold Member Username: Saqeeb9000Post Number: 3768 Registered: Oct-07 | justfforhhah is stupid, i told him so manytimes people don't need to get keys they have autoroll., i think he just wanna become a gold member... |
Silver Member Username: JustforhahasPost Number: 185 Registered: Jul-08 | sada, your an idiot. this is not the time or place to be an azzhole. We have more concerns than you. theres an ECM going on. AR has nothing to do with this ECM either jerkoff. sada, learn FTA, before you post! Help instead of contributing to the problems..quit trying to be a winner and helper, it'll never happen, you'll always be a loser and wannabee. |
Bronze Member Username: Sonia18Post Number: 14 Registered: May-08 | Sada .. is there a new bin out |
Silver Member Username: LuciaCalgary, AB Post Number: 672 Registered: May-06 | la la la la 8 Fighting online is like racing in the special Olympics; even if you win, you're still retarded. |
Silver Member Username: KingofdakingzPost Number: 317 Registered: Jun-06 | on my pansat nothing works but on my viewsat everything works |
Silver Member Username: WakenbakePost Number: 388 Registered: Mar-06 | lakh , try bin from 5-22-08 |
Gold Member Username: BrucesterPost Number: 1604 Registered: Jul-06 | and cw is geting picture but not worth watching every 2 or 3 mins get scrambled ch then tv for 2 or 3 mins then nothing same on bev with cw600p and cw650 |
Bronze Member Username: BluegillbillPost Number: 75 Registered: Sep-06 | does anyone have a binfile around april 30th that will work on pansat 2500 converted to puff |
Gold Member Username: BrucesterPost Number: 1606 Registered: Jul-06 | cw600p is up on bev with bin171 with miner freez |
Silver Member Username: JustforhahasPost Number: 188 Registered: Jul-08 | bruce 1, its good to see you contributing in a positive manner. If we all post whats working or working the best, we can all have some TV until new fixes are released tonite or tomorrow. also I presume you're talking about DN and NOT Bev. |
Silver Member Username: JustforhahasPost Number: 189 Registered: Jul-08 | my mistake bruce, I see that you said Bev |
Gold Member Username: BrucesterPost Number: 1609 Registered: Jul-06 | sorry all its bin197 not 171 sorry my bad for the cw600p go with bin197 for bev sorry again |
Silver Member Username: JustforhahasPost Number: 190 Registered: Jul-08 | These appear to be the best working files now PS 2700- 265 and 269 DN CS 5k/6k- 177 DN PS 3500- 385 DN CW 700/800- 164 DN CW 600P- 171 Bev SV 8000- 315 DN |
Gold Member Username: BrucesterPost Number: 1613 Registered: Jul-06 | justforhahas its bin197 its my bad on the last post bin 197 is up on dn and bev no freez so fare last halfhours any way just but bin in that long agao lol |
Silver Member Username: Snw7619Bahamas Post Number: 213 Registered: Oct-06 | is 265 and 269 working for pansat 2500>>2700 clones B-75 |
Silver Member Username: JustforhahasPost Number: 193 Registered: Jul-08 | Fix 274 working good on converted receivers.. |
Silver Member Username: LolPost Number: 774 Registered: Sep-06 | SV 8000- up on both bev and dn with 308P atm |
Silver Member Username: Snw7619Bahamas Post Number: 214 Registered: Oct-06 | which file for B-75???? |
Bronze Member Username: MzakcatPost Number: 64 Registered: Aug-05 | 265 or 269 for bev? or just dn |
Bronze Member Username: MzakcatPost Number: 65 Registered: Aug-05 | nevermind tested and 269 does both |
Silver Member Username: Snw7619Bahamas Post Number: 219 Registered: Oct-06 | b75 or puff |
New member Username: AhtashamPost Number: 8 Registered: Oct-07 | can someone please put a link to download the pansat2700 file? |
Gold Member Username: Saqeeb9000Post Number: 3769 Registered: Oct-07 | "this is not the time or place to be an azzhole. We have more concerns than you. theres an ECM going on. AR has nothing to do with this ECM either jerkoff. " posted by haha.. u moron u don't even know , when u are starting the the thread with fu*king key change u should had fu*c*k*king posted ,that u need a new bin, (newbees don't know). so thats why they ask for it ..so STFU |
Silver Member Username: JustforhahasPost Number: 195 Registered: Jul-08 | sada.you again are NO HELP, only wasting our time...go away jerkoff I posted there was an ECM...if you can't understand that, then leave! |
Gold Member Username: Saqeeb9000Post Number: 3773 Registered: Oct-07 | their was no need for keys .. but i guess u are an idiot.. |
Silver Member Username: JustforhahasPost Number: 196 Registered: Jul-08 | sada..you are an embarassment to yourself... as people can see by this thread, WHICH I STARTED , and told everyone about 2 ECM's, and posted HELP throughout this thread, You have contributed NOTHING here, as usual, except your wannabee attempted bashing of me, who has been helping others during this ECM.. This thread is a perfect example of my intentions, and yours ...yours to bash...mine to help.. The members here should banish you as you have lost the respect of many here now, I'm sure. |
Gold Member Username: Saqeeb9000Post Number: 3774 Registered: Oct-07 | Sonia Bronze Member Username: Sonia18 Post Number: 13 Registered: May-08 Posted on Thursday, August 28, 2008 - 05:28 pm: -------------------------------------------------------------------------------- so i just put the keys in right?? there's new bin change? Zunna Silver Member Username: Zunna Post Number: 269 Registered: Jun-06 Posted on Thursday, August 28, 2008 - 05:29 pm: -------------------------------------------------------------------------------- i put these in and it says searching or keys? these posts proof that haha is actually helping the newbees..keep up hahha |
Bronze Member Username: PicanhaEast LA Post Number: 55 Registered: Jun-08 | Lotsa good stuff in this thread!!! |
Silver Member Username: Hoosier_daddyPost Number: 178 Registered: Dec-06 | anything working on a puff? |
Silver Member Username: JustforhahasPost Number: 198 Registered: Jul-08 | -------------------------------------------------------------------------------- CW 700/800 are up on bev and DN with fix 177 CW 600P is up on 197 fix..DN and bev Sonicviews are up on fixes from 29/30 May..like 232/233 etc PS 2700 and Puff- up on 271, 268, 269, 274 PS 3500- up on 385/386 |
Gold Member Username: Saqeeb9000Post Number: 3775 Registered: Oct-07 | there are no coders here.. we are just helpers, so stop asking for new bin, when the new bin will come , u will get the links where u can get the new file. hope it helps.. by the way haha don't get me wrong i am not trying to proof anythiig etc.. i like u help people and its good, but when u post stupid stuff, ask people to buy ur rec b.c u get commission, and that i won't accept... amen |
Silver Member Username: LolPost Number: 775 Registered: Sep-06 | shut up for christ sakes Sada |
Gold Member Username: Saqeeb9000Post Number: 3776 Registered: Oct-07 | paul what happend ? how come u don't put any naked pics anymore |
Gold Member Username: RyersonresurrectedCANADA Charlatan... Post Number: 1145 Registered: Sep-06 | I put 269 in, and can confirm dik working...it's the May 23 2008 bin |
Silver Member Username: PsychmonsterRhodium Member aint nuthin... Post Number: 901 Registered: Jul-06 | yeah HaHA,,,I thought we should look into this https://www.ecoustics.com/electronics/forum/home-video/510170.html |
Bronze Member Username: LocnoirPost Number: 83 Registered: Aug-06 | Ryerson, was it for converted pansat? |
Silver Member Username: JustforhahasPost Number: 199 Registered: Jul-08 | psychomonster...those Bev secondary keys were input into the stream 0907 yesterday, but NOT activated until today..thats why the Bev ECM...same with DN 0106 keys today...so coders have NOT learned to AR those secondary keys yet |
Bronze Member Username: FatbackPost Number: 21 Registered: Jan-08 | Anybody got a link to bin 269 for b-75???????????? |
Silver Member Username: JustforhahasPost Number: 200 Registered: Jul-08 | June 13 fixes are working well for Viewsat and Sonicview owners, on BOTH DN and Bev. |
Silver Member Username: PsychmonsterRhodium Member aint nuthin... Post Number: 902 Registered: Jul-06 | 271 jvvh puff,,,no freeze...this is the ticket ..all others have freezes |
Bronze Member Username: AngelquinPost Number: 24 Registered: Jul-07 | It looks like a lot of old bins are working. These work very well: PS 2700 with 272. SV HD 8000 with 309. |
Platinum Member Username: NydasPost Number: 11440 Registered: Jun-06 | PUFF_272 working. https://www.ecoustics.com/electronics/forum/home-video/511174.html |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 3527 Registered: Jan-08 | Hahaha Idiot Viewsat never go down like Sonicview |
Silver Member Username: JustforhahasPost Number: 201 Registered: Jul-08 | Viewsat went down on Bev for many people..they had to use 13 June old files. Sonicview, then Pansat released the first new fixes..which are now posted at most all sites...Viewsat and others will probably follow soon.. |
New member Username: Nydu_sPost : 15899 Post Number: 2 Registered: Aug-08 | PUFF_272 not working. https://www.ecoustics.com/electronics/forum/home-video/511174.html |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 3528 Registered: Jan-08 | Hahaha Viewsat is up on both idiot Hi false Nalin |
Bronze Member Username: CiscomxPost Number: 27 Registered: Jan-07 | Bin 287 is out for Pansat 2700 at ftabins.net |
Silver Member Username: JustforhahasPost Number: 202 Registered: Jul-08 | New files released and posted at most all reputable sites now Sonicview Pansat Captiveworks 2500-2700 Converted receivers FTA View [link removed] (all receivers) Data Viewing Sequences [link removed] ( Conaxsat and all receivers) FTA Bins [link removed] (C00LSAT and All receivers) FTA For All [link removed] (Captain and Captiveworks) Dss Rookie [link removed] (Nfusion and others) Cut and Paste these into your browser: REMOVE the * in links below: These are the larger popular sites,and therefore Ecoustics has blocked their names and active links.. |
Silver Member Username: PsychmonsterRhodium Member aint nuthin... Post Number: 905 Registered: Jul-06 | 271 jvvh puff,,,...this is the ticket .. don't know about the 287 but if there are glitches, this bin is wide open on Bev and DN with no freezing |
Bronze Member Username: King_of_ratsPost Number: 55 Registered: Jun-08 | |
Bronze Member Username: PicanhaEast LA Post Number: 56 Registered: Jun-08 | Never Heard of That Biotch but: |
Bronze Member Username: King_of_ratsPost Number: 56 Registered: Jun-08 | |
Silver Member Username: PsychmonsterRhodium Member aint nuthin... Post Number: 907 Registered: Jul-06 | Boba Fett Bronze Member Username: King_of_rats 271 jvvh puff,,,...this is the ticket .. don't know about the 287 but if there are glitches, this bin is wide open on Bev and DN with no freezing...stay on the threasd,,,start your own thread for bashing..plus take a eeg to see what part of your brain is not gettin oxygen |
Bronze Member Username: King_of_ratsPost Number: 59 Registered: Jun-08 | |
Platinum Member Username: NydasPost Number: 11446 Registered: Jun-06 | Always go to "home site of your receiver" first. The sites in BOLD offer direct downloads without registration. [link removed] - VIEWSATS [link removed] - Ariza and Pansat Conversions [link removed] - C00LSATS and Nfusion [link removed] - CaptiveWorks. [link removed] - Nfusion Other reliable sites: [link removed] |
