NPS
Username: Mucho
Post Number: 559
NPS is one of America's premier C-Band programming providers.
They list close too (200) Prime Time
Channels.
Can any of their Channels be picked up
on a C-band installation?
Do they have their own Satellites or do they rent from another provider?
Btw, has anyone Teddy? he is the C-band man.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3533
White
Which satellite?
Username: Det
Post Number: 73
why isn my epg working for channls on anik f3 on my pansat 2700a?it works for every other echo that im using such as echo 7 and 8.10 but not anik it was working before.
Username: Plymouth
Post Number: 3534
White i found it
http://www.callnps.com/chart.htm
Username: Plymouth
Post Number: 3535
Sorry good link
http://www.callnps.com/digital_feeds.htm
Username: Tdti1
Post Number: 81
I use both NPS and SRL for my 4dtv programming, there is also YSP but they got bought out by Dish net years ago and push pizza pans on there customers.
NPS and SRL make contracts with the networks to give 4dtv users the ability to subscribe to the distribution feeds, they blow away pizza pan big time, as the picture and sound are fantastic.
The 4dtv is DCII so a sub is required, you can grab a 905, 920 or 922, if it's used make sure the unit ID is good, and get the battery replaced asap, if it's over 8 years old.
NPS and SRL also have a deal with HITS (Headend in the sky) the picture is slighty better than pizza dish but not that great as they are not the main distribution feeds, you can sub to these with a 905, 920 or 922, if you only want the HITS channels then a DSR 410 can be used, though it must be purchased from Skyvision, or any other SRL programming reseller.
Username: Tdti1
Post Number: 82
SRL (satellite receivers limited) http://www.programming-center.net/
NPS (national programming service) http://www.callnps.com/
YSP (your service supplier) http://www.superstar.com/index.asp
Username: Tdti1
Post Number: 83
Oops YSP is your service provider, sorry.
Username: Mucho
Post Number: 562
Thanks Plymouth, nice info.
Thanks Teddy, like I said you are the "C"
man, stick around I am thinking about
installing a BUD.
