Username: Nydas Post Number: 11437 Registered: Jun-06
Friday, August 29, 2008 - 03:09 GMT PUFF_272 BIN works for today's ECM. I have not tried the b75_272, but it should also work if you have b75 conversion. [link removed] [link removed] Please read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Psychmonster Rhodium Member aint nuthin...
Post Number: 904 Registered: Jul-06
Friday, August 29, 2008 - 03:18 GMT 271 jvvh puff,,,no freeze...this is the ticket ..all others have freezes
Username: Csb3 Post Number: 30 Registered: Sep-06
Friday, August 29, 2008 - 03:24 GMT tried the 272 b-75 works fine. thx nalin
Username: Nydas Post Number: 11443 Registered: Jun-06
Friday, August 29, 2008 - 03:26 GMT I haven't tested PUFF_271, but psychmonster is a good tester so I beleive him. The PUFF_271 have been posted at [link removed]
Username: Aryan Mississauga,
Ontario
Post Number: 78 Registered: Nov-07
Friday, August 29, 2008 - 10:34 GMT nalin, what are yr veiws on this http://www.ftabins.net/showthread.php?t=52949 thanx
Username: Dimwitt Post Number: 853 Registered: Aug-06
Friday, August 29, 2008 - 10:59 GMT My view : 287 is latest BL bin for the 2700 and now it has been modified to run in the 2500 and its clones. if you are happy with the way your stb is operating - don't try it , if unhappy give it a try.
Username: 3dges Compton
Post Number: 41 Registered: Feb-08
Friday, August 29, 2008 - 14:34 GMT just tried 272 for b_75 it works fine
Username: Det Post Number: 71 Registered: Jan-08
Friday, August 29, 2008 - 14:48 GMT why isn my epg working for channls on anik f3 on my pansat 2700a?it works for every other echo that im using such as echo 7 and 8.10 but not anik it was working before.
Username: Nydas Post Number: 11447 Registered: Jun-06
Saturday, August 30, 2008 - 15:10 GMT Ary an: Black Tyger BINs have been around for a long time and usually they are reliable. Like everybody else, occasionally he puts out a bad BIN - mostly because of the competition to get the modified BIN out quickly. ftabins as a site has too many people posting BINs, so you should rely more on the original site crazyfta, which often has problems of access.
Username: Nydas Post Number: 11448 Registered: Jun-06
Saturday, August 30, 2008 - 15:13 GMT The latest conversion BIN is 287 FLU/2500 Conversion to 2700 workalike. Full kits for Latest conversion BINs and other files - also for Revert to 2500 [link removed] [link removed] Please read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
