i have a better head unit than my standard speakers could take so need new fronts in the 306... 16.5cm diameter... i found some nice ones they were about £60/ $115 for the pair but the diameter of the back bit wont fit into fitting.. can someone suggest what would, or if i should carve out a bigger hole... the head unit has 4x52 W output... i like bass but a good quality aswell. also thinking of replacing parcel shelf speakers... any suggestions?
Hey Doug, do you know the allowances for what WILL fit into the speaker hole? This would make finding a speaker quite a bit easier. What is your overall budget? Are you looking for a component system or coaxials?
16.5 cm normal diameter, haven't measured anything else... will do tomorrow and write then... but dont really know exactly what to measure... and i have NO idea what coaxial or component means... but i dont want seperate tweeters... budget is prob £60 max without feeling guilty... but that gives lots of options i think. i just bought a set of JBL GT0627 with 60 watt RMS and 180 watt peak cos they sounded good in the shop and i thought they would fit... the other option is carving a new shape in the fitting place so they fit... but i wouldn't knowhow to go about this?
