Hello Everyone, I am presently experiencing this problem with my Sonicview 4000 Receiver. The problem that I am experiencing is I am getting NO Signal on my television screen. Whenever I do a blind scan on my receiver, I am seeing all the channels appearing and also my signal strength. When I exit out of the menu, I am getting No Signal appearing on my television screen. I hooked up, another receiver to the same cable coming from my dish, and I am getting picture and also signal strength. I change my LNB type to Universal and Single in thr Dish Setting Menu and it is not working. I flashed my receiver with the Factory bin then with SV4000_V0249P_Charlie_Fixed_081308.bin and it is still not working. My Setup is as follows:
1 12ft Solid Prime focus Dish 2 California Amplifier for Prime Focus Dish 3 Single Cable run from the LNB straight to the Receiver.
I would grateful if you can assist me in having my problem resolved. Thanks in advance.
