Username: Shade Moxee,
Wa
U.S.
Post Number: 716 Registered: Nov-06
Tuesday, August 26, 2008 - 02:34 GMT so...burped a sundown 3k on a btl 18, with 2 yellowtops, 1 red top and a hc2400.....fuse holder was trying to melt...any ideas? oh sundown was at .5ohms and i never dipped below 12.8 on voltage...perhaps trying to pull to much power throu the 1/0g?
Username: Surferdude9371 Im BTL Bumpin
Post Number: 1175 Registered: Mar-07
Tuesday, August 26, 2008 - 02:41 GMT whats the fuseholder near any engine parts?
Wa
U.S.
Post Number: 717 Registered: Nov-06
Tuesday, August 26, 2008 - 02:45 GMT the near the amp.... also did a 147.2 on music with a single 18" in 4.5cu with external 6" aero's
Wa
U.S.
Post Number: 718 Registered: Nov-06
Tuesday, August 26, 2008 - 02:50 GMT so basically, do i need to ad another run? or should i go about diagnosing this like it's a bad ground?
Post Number: 1176 Registered: Mar-07
Tuesday, August 26, 2008 - 02:51 GMT sounds like too much draw getting the wire too hott grats on the score btls are beasts
Username: Rovin 1 15 = 149.5 DBsTrinidad & T...
Post Number: 14129 Registered: Jul-05
Tuesday, August 26, 2008 - 05:22 GMT nice score ...
Wa
U.S.
Post Number: 719 Registered: Nov-06
Tuesday, August 26, 2008 - 21:28 GMT lol thnx but i really wanna make sure that when i go back to meter again i don't have this asme problem? any suggestions rovin?
Username: 04redmach1 Es DEALER,
GA
Post Number: 2303 Registered: Mar-06
Tuesday, August 26, 2008 - 21:59 GMT What brand wire are you using? Are you melting fuse, or the fuse holder all together? Where is fuse holder located? Kevin
Post Number: 1177 Registered: Mar-07
Tuesday, August 26, 2008 - 23:59 GMT he said holder is right by the amp
Wa
U.S.
Post Number: 720 Registered: Nov-06
Wednesday, August 27, 2008 - 00:24 GMT yah, the fuse holder is next to the amp between the batts....it's also fused by the front batt too. and the fuse cap, turned brown in a spot and under that spot the actual fuse was black. asfor the wire i'll have to get back to u on that.
Wa
U.S.
Post Number: 721 Registered: Nov-06
Wednesday, August 27, 2008 - 00:25 GMT lemme see if i can get some pics for u later 2night.
Username: Southernrebel Monroe,
Louisiana
3 DD3515s, 2...
Post Number: 6663 Registered: Mar-04
Wednesday, August 27, 2008 - 00:35 GMT Check your resistance across the fuse-holder. I bet you have a bad connection. Your fuse or holder my be defective or just not a good enough connection. Also, make sure your wire gauge is up to par.
GA
Post Number: 2308 Registered: Mar-06
Wednesday, August 27, 2008 - 00:58 GMT Reading>me haha. I agree with Canaan. Check it out bud. Kevin
Post Number: 1179 Registered: Mar-07
Wednesday, August 27, 2008 - 01:04 GMT if the wiring isnt melting i would think that it would be a connection issue also
