Need some help
Username: Toyotwincamgt
Arroyo, Puerto Rico United States
i have two solo baric kicker 15' L7 2000 watts and 1000rms i dont know what amp i need to move this subs i check on ebay 1 lanzar maxpro of 4000watts 2 omh 2 channel and 1650rms x 2 total rms 3300 watts for 160$.this amp its good for my solo baric or no? Upload
Username: Chevelle
Lancaster, Pa Usa
Post Number: 96
For a few more dollars you can get a kx.2500.1 mono amp.You can try lanzar it might push those my buddy had the same and it push one and was loud if not you can sell it or get a set of 12"
Username: Insearchofbass
Post Number: 10274
Dont buy that Lanzar amp they are junk. What ohm voice coils does your kicker l7 15 have?
2 ohms
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5473
that amp won't work at all
why? my buddy have one lanza vibe 1800D 1 ohm with 2 zeus 15'
Username: Ridinspinnas
Windsor, Ontario Canada
Post Number: 437
first of all, peter, since when can u get a kx2500.1 for around 160 dollars, send me a link ill buy a few, and yes that amp is pretty garbage, if you want to go cheap, but still not that bad, hifonics, is a decent bang for the buck
