Lost American Channels
Username: Samgethim
Can Someone help me - to get american channels back- I have CW600s -Dish Pointed with 61.5,110 and 119. Right now iam getting channels only from 61.5. I tried scanning for 110 and 119, I did not get any american channels. Can Someone tell me what TP settings i have to use...
Username: Kirankumar
NO Bashing
Post Number: 2922
post your antenna settings for all 3 satellites here so we can help you
Username: Samgethim
Thanks Kiran
LNB1-61.5 -12326/H/2000/AUTO
LNB2-110-12516/V/2000/AUTO
LNB3-119-12384/H/2000/AUTO
NO Bashing
Post Number: 2928
Sam
i need
Lnb type
lnb freq
tp freq
disqc port
22mhg
give me details on all 3 satellites
Username: Samgethim
Post Number: 7
Satellite-61.5
Transponder -12326/H/20000/Auto
LNB Freq-11250
LNB Type -Normal
22khz-Auto
Diseqno-LNB1
Satellite-110
Transponder -12516/V/20000/Auto
LNB Freq-11250
LNB Type -Normal
22khz-Auto
Diseqno-LNB2
Satellite-119
Transponder -12384/H/20000/Auto
LNB Freq-11250
LNB Type -Normal
22khz-Auto
Diseqno-LNB3
Before it was working perfectly when technnician installed. Once i had a problem with Reciever - I reset to Factory setting i Lost all settings made by technician, Only i can recover 61.5(LNB1) settings and channel.For LNB 2 & LNB3 i tried by different settings doesn't seems to help. The above are current settings in the reciever.
NO Bashing
Post Number: 2929
ok for 110 change tp freq to 12224
and for 119 change tp freq to 12457
and you will see quality pop up and correct satellite will pop up on top right hand corner
NO Bashing
Post Number: 2930
Sam,
if that does not fix the problem then i need you to do this.
turn receiver off,go outside to switch and swap out port 1 and 2
now go inside turn receiver on,
of you have lost 61.5 and 110 is on,then you have a blown switch.get a new chieta heavy duty switch.
before you replace the switch make sure to switch receiver off from back and this time
hook up satellites as follow
119 > port 1
110 > port 2
61.5 > port 3
then turn receiver on and adjust antenna settings by assigning
119 > lnb 1
110 > lnb 2
61.5 > lnb 3
Username: Samgethim
Post Number: 8
Kiran,
there is no problem on the signals or quality..
As per your TP settings i tried scanning again, Iam not getting american channels, Discovery.. PPV...
NO Bashing
Post Number: 2931
so when you go to antenna settings and pull up satellite 119 or 110 are you getting good signal and quality ? both
Username: Samgethim
Post Number: 9
yes
NO Bashing
Post Number: 2932
ok,
go ahead and write down antenna settings for all 3 satellites and do factory reset
then do hard reboot
go back in and adjust antenna settings and scan all three satellites
Username: Samgethim
Post Number: 10
Kiran, you are Pro..
Excellent Solution. works now.. thanks for all your help
NO Bashing
Post Number: 2933
glad your problem got resolved
enjoy
Username: Honeyji
Star plus suddenly disappeared on my converted 2700 can someone please help me
