Popping Sound?
Username: Cplaya280
Pennsylvania USA
Post Number: 945
I have a 15" Audiopulse Revo and it sounds great but when it goes for the low notes sometimes theres a big pop and it scares me everytime it sounds like a backfire sound or something anybody know what this means? im running the AQ2200D on this sub I did have the bass boost up a little bit but i just turned it down but idk if that would be causing the popping sound.
Username: Th3pwn3r
I compensate...
Post Number: 8618
Do you have your filters set properly? Are you sure the sub isn't bottoming out?
Username: Cplaya280
Pennsylvania USA
Post Number: 946
I actully never messed with the subsonic filters i know my amp has it but idk what i would set it to i know my sub is ment to hit really low tho the fs for my sub is 22hz. That could be what its doing tho is maybe bottoming out its like a pop when it trys to get extra low but when i was using my 2 12" 17's i would play the same songs and they would never pop when it went extra low so i really don't know
Username: Cplaya280
Pennsylvania USA
Post Number: 947
bump
Username: Exige
CDT, Audiopulse Dealer
Post Number: 648
You're likely bottoming out. Check what your subsonic filter is set to and let me know.
Username: Cplaya280
Pennsylvania USA
Post Number: 948
i have it set to 0 i dont have the filter set i never used the subsonic on any of my system setups should i deff be using it and if so whats a good place to set it my box is tuned at 32hz and the 15" AP Revo the FS is 22hz
Username: Somedonniedude
Illinois United States
Post Number: 1960
Try setting it at ~24hz and see if it still does it. If so keep going up until it stops making the noise.
Username: Cplaya280
Pennsylvania USA
Post Number: 949
alright im gonna try that and if it still does it then the idk what else it can be
Post Number: 1961
Were your L7's sealed? JW.
Username: Exige
Post Number: 649
Chris check your email.
Username: Stateprop486
PA
Post Number: 1570
nah his l7s was ported. i was with him today n i heard the pop sound too the one time it did it 2x in a row and it made him jump all the times it did it.
Username: Cplaya280
Pennsylvania USA
Post Number: 950
im gonna try out the subsonic to see if that makes any difference its just wierd i never had to use a sub sonic filter on my l7's i had for like 3 years but i did notice when i had a 15" l7 back then that used to pop once in a while to but when i have 2 12's they never pop anybody know why that is? my guess is because the 15 hits a lot deeper then the 12s which can cause bottoming out?
Username: Van_man
Boston South, MA
Post Number: 4235
were you listening to T.I. ? big things popping?
also is the gain set right?
Username: Cplaya280
Pennsylvania USA
Post Number: 951
i set the gain by ear it was only a little past the middle but i did have the bass boost a little past the middle to but then i turned it down alot so idk if that could have effected it but when i had my l7's set the same way they was fine no popping or anything im still gonna try out the subsonic first to see if that makes a difference its only on the really low notes it pops tho it happend on the song
THE DREAM - I LOVE YOUR GIRL which hits realy deep
PA
Post Number: 1571
"were you listening to T.I. ? big things popping?"
no he wasnt listening to that. haha
lmao......
Post Number: 1969
Any results???
Username: Cplaya280
Pennsylvania USA
Post Number: 957
i turned my subsonic on to about 27hz and i turned the bass boost from half way up which was 5db out of 8db max i now have the bass boost on at 2db max and there is no popping at all this sub gets crazy loud and low thanks for the help guys no more popping i can enjoy the music now without worrying about the sub bottoming out.
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 1015
time for a vid
Username: Hittin1
Lake Charles, La. United States
Post Number: 1128
ummmmmmmm, Vid and Pics...
Username: Exige
Post Number: 652
Username: Cplaya280
Pennsylvania USA
Post Number: 958
Heres the link to the pics https://www.ecoustics.com/electronics/forum/car-audio/510079.html
I still gotta make them videos tho probably get to it within a day or two
