How to download bin into the box?
Username: Sonia18
i've heard people do it themselves but i dunno how to do this so can some1 help me i have pansat 2700 can somebody give me the latest bin and instructions on how to do this
Username: Justforhahas
Post Number: 112
I recommend you do some reading at one of the many DSS sites on the internet. Any DSS site will have the info, files, and manual for your 2700.
Username: Kirankumar
NO Bashing
Post Number: 2914
i don't have a pansat,but assuming you have and original 2700 and not a converted one,then you would download latest file to your desktop,and unzip it.you would also download 2700 loader to desktop and unzip it.
now you would turn your receiver off and hook up the rs 232 cable that came with the receiver to the computer and receiver.open loader,bring in uzipped file and hit download and at the same time turn receiver on from the back.
do not power receiver off until download is complete.
NO Bashing
Post Number: 2915
sorry you can find all files and loader
at www.ftabins.net
just register there it is free and if you go to the pansat forums you will get more help if needed
good luck
Username: Mucho
Post Number: 539
African
If they were to vote here today for the nicest person
that comes here with lot of class you would be my choice.
No bashing just trying to help.
NO Bashing
Post Number: 2918
thank you sir
Username: Rtap
FL
Post Number: 2237
1.download loader v27.02 and download current bin and extract bin from zip file
2.open loader and press select bin and choose the correct bin
3.have 2700 on and connected via nullmodem cable not db9 cable to computer
4.hit download and wait when complete check your settings in antenna setup and make sure all is ok
5.have autoroll on,scan your birds and watch tv.
good luck
Username: Sonia18
African & RTAP
sorry i forgot to write its a converted one. it was 3000 before do i do the same thing for this and which bin do i use?
thx for ur help
Username: Sonia18
Post Number: 7
and also ..i have a usb null modem is tht ok?
