New member Username: BqtootPost Number: 1 Registered: Aug-07 | I've read till my eyes bled and can't find it. Anyone have a wiring diagram for this head unit? Much appreciated. |
Silver Member Username: Cd5honda96OR United States Post Number: 117 Registered: Jun-08 | This might be able to help you out ..maybe http://www.bulldogsecurity.com/wireing%20diagrams2.htm |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1441 Registered: May-07 | or this might help to. http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/ CD/model.CQ-C1101U |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1443 Registered: May-07 | i forgot to mention 2 things, pioneer keeps the same layout of colors and i believe alpine does to on thier harness so if u can find a diagram for a newer panasonic you should be fine. all u really need to know are the speaker colors. atypical layout is red/whit -power antenna, Red - positive, black - ground, yellow is clock, red skinny wire or orange skinnny wire is the Acc wire yellow sometimes to. blue is the REM. your speaker wire range from 4 wires of purple, green, white, grey, brown, orange and one has a stipe for the negitive wire those would be 2 for front left, 2 for front right, 2 for back left, 2 for back right. in the end for a 2. option, call panasonic they should set you up or tell u the pin out. |
