SERIAL USB CABLE
Username: Lizwakefield
Post Number: 71
HI CAN SOMEONE PLEASE TELL ME WHAT CAN OF USB CABLE I NEED FOR MY LIFETIME ULTRA. SO I CAN TRANSFER THE FILES OVER THE LAPTOP INSTEAD OF THE COMPUTER
THANK YOU
Username: 1rbjac
Long Beach, CA US
Post Number: 22
You need a serial to USB cable, then all you have to do is hook the serial end to the cable that came with your unit.
Username: 1rbjac
Long Beach, CA US
Post Number: 23
You need a serial to USB cable, then you can hook it up the serial end to the cable that came with your unit.
Username: Jowhar
Post Number: 282
https://www.ecoustics.com/electronics/forum/home-video/506192.html
Username: Nydas
Post Number: 11355
Why would not use a under $10 USB drive and save yourself a lot of problems?
