New member Username: DisrespectfullPost Number: 3 Registered: Aug-08 | can my 1200 watt xplode push two 12 inch kicker comp cvrs dual 4 voice coils and whats the best way to hook them up |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1902 Registered: May-07 | It will work, but you should get a bigger amp. Wire each sub to a separate channel, with each sub wired to a 2 ohm load in figure 1... http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=1&woofer_imp=4 |
Silver Member Username: WaresgaragestereoFort Valley, GA Post Number: 273 Registered: Mar-08 | u get 600 watts @ 2ohm x2 |
Gold Member Username: Drant19DUB-C, TX Post Number: 1092 Registered: Aug-07 | ^^^^and thats overrated... get a diffferent amp for those keekers |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1612 Registered: Mar-04 | "u get 600 watts @ 2ohm x2" Probably 200-250 x 2 knowing Sony and their "1200 watt" ratings. It should be enough to get some decent performance out of them, but not nearly enough to get their best. I'd bridge it and wire them like this... |
Silver Member Username: WaresgaragestereoFort Valley, GA Post Number: 307 Registered: Mar-08 | that would work |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 964 Registered: May-07 | what is your budget for an amp to push your subs... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5457 Registered: Dec-05 | i'd suggest a hifonics 1206d |
