BTL 18 help with new box
Username: Surferdude9371
Im BTL Bumpin
Post Number: 1113
summertime again meaning time for a new system but i love my btl so im gonna build a new box instead (after i finish those fiberglass door panels :-( going on 2months now) anyway box is gonna be about 7cuft at 33hz im going with 4 flared ports. question is do you think i should go with 4 of the the 4" ports or 4 of the 6" ports. i will be still running of a KX2500.1 thanks for your help.
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2404
i dont have much experience with fi products but 4 4" ports seems a little low on the port area for an 18" BTL so if it were me ide go with the 6" ports
Username: Tejcurrent
Post Number: 1433
I'd go with 6" if you could. More port area with that amount of power would be a good thing for output if that's what you're after.
Im BTL Bumpin
Post Number: 1114
ok ill go with the 6's will 4 be enought i can prob fit 6?
Username: Deadrabit
Post Number: 656
i would go with 4 of the 6"
Username: Insearchofbass
Post Number: 10156
Id go with the 4 four inch aero ports. I think it will provide a higher output on the upper bass and still be good on the lows. I think four six inch aeros will be too much port area and will provide mostly low end frequency output.
Im BTL Bumpin
Post Number: 1119
sean do you think i should do 4 or 6 of the 4"?
Post Number: 10165
I think you should do four. Chad did two 4 inch aero's like I recommended on 1200-1500 and it worked but he moved the tune up to 36 hz instead of the intended 32 hz because of space issues but I think four will work for you at 33 hz.
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2100
4 4" would work perfect.
Im BTL Bumpin
Post Number: 1120
thanks guys
