Subs getting hott????
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 444
i have two tc sounds 1ks or epic wired to one wire to an ed nine.1 and the subs the past 2 days are starting to get hot when bumping them...turn gains down or what????
Username: Somedonniedude
Illinois United States
Post Number: 1965
Sounds like clipping. Have you adjusted anything on your amp latley? If not, go through your HU, and turn down your sub a bit. Any particular new songs or cd your listening to lately? Might have a poor recording or something too.
Username: Surferdude9371
Im BTL Bumpin
Post Number: 1162
if its the just cap and its getting hot but not burning hott that happens if the glue around the spider gets hot or the dust cap is burning hot then id be worried
Username: Prozack52
Post Number: 446
actually new songs but they are songs on the actual artist released cd
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14131
yep try turning gain down & using more vol on ur HU to get better\cleaner output ....
Username: Th3pwn3r
I compensate...
Post Number: 8623
Use your ear and listen for distortion. If you're clipping you should be able to notice that it doesn't sound too good and clipping will cause your subs to heat up pretty badly.
