FLU/2500 Conversion to 2700 workalike. Full kits for Latest conversion BINs and other files - also for Revert to 2500
[link removed]
[link removed]
[link removed]
Please read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
There is also a DIY method for converting and installing any of the 2700 group of receivers, i.e. genuine 2700, clone 2700 and converted 2700. [link removed]
Nalin i tried the puff but it would not go it say not a good file or something like that . Now i have Vista windows maybe that is the case . i can't find the Puff file anyhwere else thanks
just still messing around with jvvh puff...put provider back to 0101 and recscanned and loaded dirtv 1,2,4 and after 17 minutes of scrambled it kicked in for Bev channels sat at which is where I am aiming at...I guess patince is a virtue, but so is 2 1mg xanax
Yes Nalin i am usinga usb port , But i finally got that one too , i used the loader 1.4 and i had to hit it as soon as it came on . i been waiting until it came on and then i wouldn't lose my setup but got that one too Thanks for your reply
