Worth picking up?
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 436
http://cincinnati.craigslist.org/ele/787344772.html
may not even be blown but he doesn sound like he nos what hes talking about i would def ohm it out before i buy it if not is it repairable?
Username: Th3pwn3r
I compensate...
Post Number: 8532
The problem is if it is blown. What are you going to do with it? To my knowledge those subs can't be reconed.
Username: Exige
CDT, Audiopulse Dealer
Post Number: 629
it's always repairable through JL, the question is cost. Grab a DMM and check it out. could be a great find if it actually works.
Username: Th3pwn3r
I compensate...
Post Number: 8533
I thought JL didn't recone subs. Do they?
Username: Wickedbass
JL does rebuild the w7 drivers. You would have to take it to a dealer who would then send it to the factory in Fl. The cost would be around $350 plus shipping to and from. Its def. worth checking out (depending on how far it is from you). Like Exige said take a DMM, if its fine cool, if not i wouldn't bother. You could find a good used one for less than u would if that one is blown.
Username: Nd4spd18
Northwest PA
Post Number: 8148
That would be an awesome find if it's good. You could resell that for a $300+ profit.....
Username: Ridinspinnas
Windsor, Ontario Canada
Post Number: 406
tell him its blown and offer him 60 bucks cash, either way then thats a decent buy
