I was wondering if u could power mount kicker l7s
Username: Biggiesize92
Howey in the hills, Fl Usa
yea i was just wondering if i could power mount the kicker l7s and if they would sound good still
Username: Southernrebel
Monroe, Louisiana 3 DD3515s, 2...
Post Number: 6620
Power mount?
WTF is power mount?
inverse?
Username: Loudnproud
Post Number: 37
dumb question....but what is power mounting?
Post Number: 38
lol, I see you're still up late too Canaan....and posted just a bit before I did
i mean like flip like inverted like magnets out
Post Number: 39
ah, yeah....thats INVERSE mounting
and I've never heard of L7s sounding too good either way...loud yes, good no
Username: Nyyfan13
15 Mag USA
Post Number: 10169
Yes, you can. Its called inverse mounting. Won't be any difference in sound or output but you may notice some mechanical noise, not certain about the L7 though.
well like i posted another fourm but wat do u think is a good 12" for under 600 dollars that can be "inverse" mounted that sounds amazing and good
Post Number: 42
lol, name change...anyway...just wondering...WHY do you want to mount them Inverse?
Only reason for it is "bling" value...doesnt help them sound any better
true true i know that i might not got so many ideas i just need to find a badass 12" sub got any ideas
Post Number: 44
I'm not gonna keep going back and forth between your 2 posts...lol, lets keep it on the other on...go there and answer my question as to what type of system you want.
Post Number: 6621
Just wondering, where did you hear inverse mounting called 'power mount'?
Also, what do you consider 'sound amazing'?
What systems have you heard that you liked?
Username: Surferdude9371
Im BTL Bumpin
Post Number: 1111
ive heard it called power mount b4 too. ony real diff between reg mount and power/inverse mounting is that when you inverse mount you take away the sub displacement usually sounds about the same.
