Cut outs of mdf
Username: Deadrabit
Post Number: 644
i am cutting out parts for my box and i was wondering if there is a program that i can use to draw out the best way to cut off the sheet so i wont waste any mdf.
thanks
Username: Nyyfan13
15 Mag USA
Post Number: 10166
Piece of paper and a pen always worked well for me.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 2732
^took the words right outta my mouth
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2534
Yea just do it on a piece of paper. If you're lazy then Fishercustoms does it for 2 dollars. If you have Google Sketchup you can do it on there too. That's probably what fisher does.
http://fishercustoms.com/services.html
Username: Bjfish11
Garden Plain, KS USA
Post Number: 461
Nope I dont use sketchup to do it. That would take much longer than the program I use.
Username: Deadrabit
Post Number: 647
well what program do u use then>
i use sketchup but that would take to long.
i am halfway done cutting.. i am just cutting away at wat ever i feel like,
but it would be really helpful to know what u use
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1684
yea fisher what program do u use?
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14094
its simple maths man - no prog or degree needed ....
Username: Bjfish11
Post Number: 462
I use a program called Cutlist Plus. While yes, it is easy to figure a layout in your head. There is nothing more convenient and efficient than this program. Makes giving quotes on custom boxes so easy. Just type in some numbers and it gives me the amount of material I use, plus I can set the cost of each sheet and it tells me the overall cost of the material I need.
Username: Deadrabit
Post Number: 658
thanks man! lots of help!
