Amp overheating
Username: Yfz_rcr_12
NC
Is it normal for an amp to get very warm? It's not to hot to touch, but it's very warm. If it isn't normal, what can cause this?
Username: Hittin1
Lake Charles, La. United States
Post Number: 928
yes it is common for you amp to get warm... very warm in fact. What amp are you refering to and what is it pushing?
Username: Hittin1
Post Number: 929
and where is it mounted?
A pic is worth 1000 posts!!
Post Number: 17723
Warm is gooood.
Upload is baaad.
NC
well it's a clarion apx 1300 pushing a 13w7, but the amp is only temporary.
Username: Quirky
SA, Texas
Post Number: 301
http://caraudioclassifieds.org/index.php?topic=121.0
just stumbled across this, looks like a good buy for that W7.
Username: Nd4spd18
Northwest PA
Post Number: 8095
That is normal. Also some amps run hotter than others, and it's not bad if the heatsink is hot. It IS bad when the amp shuts off and is extremely hot.
Username: 420alldaylong
Post Number: 3794
clarion apx 1300
400x1 at 4ohm
300x1 at 2ohm
Your W713" can be wired to .75ohm or 3ohm.
Do you smell anything while bumping the sub.
Username: Nd4spd18
Northwest PA
Post Number: 8098
Hey good call joey. If thats wired to .75 you're gonna burn up that amp.
NC
Post Number: 7
I have it wired in a series. Another thing i am concerned about is voltage drop. The voltage changes alot even when the car is running.
Username: Nd4spd18
Northwest PA
Post Number: 8102
Well the sub is wired right then, 3 ohms.
But if your voltage is dropping that much, it's HO alternator time no 2 ways about it. And a better battery would be good also.
And damn, if you're getting that much voltage drop with only a 400w amp you're really going to need a beefed up electrical for anything bigger.
NC
Post Number: 8
Would the amp in the link above be a good amp to push my w7? Also, is it stable bridged at 3 ohms?
Username: Teamrevolution
ATLANTA, GA USA
Post Number: 325
I get my amps hot enough to cook an egg.
Amps have diffrent temps they can reach before they go into protect or fail.
Check your input voltage and your voltage drop to see if there are problems. If either is lacking you will run the amp hot. A bad ground can also cause it to heat up fast.
But when you run a amp SUPER hard for a long time they are going to get rather hot. Make sure you keep good air flow to them.
Username: The_image_dynamic
San Diego, California
Post Number: 4458
Agreed. Class A/B amps, like DLS for example, get especially hot because the push-pull design causes power (efficiency) loss and relies heavily on traditional heat dissipation. Most modern amps are built especially for high internal temps, and the components, circuit boards and glues are all far better at handling heat then even a few years ago. Also, most will ramp down (reduce power output) when the circuitry senses that the amp is nearing protect mode.
The key to having an amp that will last a long time is to have adequate airflow all around the chassis, even underneath. It also helps the amp fans to expel the hot air if there is cool air circulating around, and not equally hot trapped air that defeats the fan's purpose. It's a catch-22 because having your amps out in the open attracts thieves, but simple physics will tell you that heat producing components need fresh air to survive.
